clicing from left going over small to medium bumps
T4Rscott
I hear a click at the left front when I go over small to medium bumps. I believe it's time to do sway bar bushings. I saw the write up on J.A.'s website for the Energy suspension greaseable bushings. What can be used for bushings on the end links? I can't find them alone. I am going to have my mechanic check things to be sure, but even he said it sounds like sway bar end links.
Scott
go to crapzone. they have ES bushings on the shelf. If you need links, get some cheap ones that have lifetime guarantee.
Urethane doesnt like petrol grease, use syth grease (should be able to find something for brake calipers)
yes just get new end links they are 40 bucks for a decent link in canada so one can only expect less for you. Take a look at the sway bar bushings and youll see if they are broken/torn. Sway bar end is super super easy to replace to if you decide to go the DIY route :)
keep in mind if you wheel and you dont detach one end then you will continuously break the aftermarket ones.. i am on my 3rd - but thats due to my own stupidity :)
Thanks for the input. I hopefully will get a chance to check out the condition of all the bushings this week ( if weather cooperates). Let ya know what I find.
Ambrose67
