click/pop sound
adam2562
when i pull out of the driveway (entrance has a ledge) i hear a pop sound.. it sounds like it may be coming from up top. but i know with it being lifted and offroaded for 65k miles.. the balljoint may need to be replaced and i guess could be making the pop sound.. sometimes it's related with a turn of the steering wheel too.. soo inner tie rods?
If you're having this issue when pulling in to our out of a driveway with a ledge or when cranking a wheel to turn or a combination of both(especially on an incline), it could be your skid plates.
I had a horrid popping/creaking sound last year and thought it might be loose joints or CV, but it turned out to be an ever so loose skid plate(not loose enough to rattle) that would make the sound every time I did something to flex the frame. The minuscule movements coupled with the close contact of metal on metal made a hell of a racket that was not readily distinguishable nor locatable. Had the guys at the shop tighten everything up during my last service and everything has been silent since.
Just a thought based on my recent experience. Should be easy enough to check for yourself. Cheers!
My pop was a my sway bar do you have the relocation bracket installed ?
I'll check my skids but i was just under there recently.. i really need to just have someone listen for the location of the noise as i pull out.. just thought id hear different opinions.. its a different clank than when i had it nefore and fixed it by replacing sway bar bushings. And it wouldn't be the sway bar relocation bracket cuz i have kdss
patnewton
