Climate Control Bulbs
Hey Everyone,
I have a 01 Limited with the Auto AC Controls. I was replacing the bulbs with LED’s. The two for the infotainment screen came on without an issue, however the other 2 for the remote controls don’t function (I installed them in every possible orientation (-,+)). The last time I tried installing LED’s I installed one with a resistor (I didn’t know), this cause the bulb to smoke and blow immediately, could I have damaged or blown a wire along the way by doing this which resulted in the wiring for the two lights to be permanently damaged? Is there anyway I can fix it or anything else I should try? Thanks in advance.
Honestly, go OEM. Any dealer can have you the bulbs in a day or 2, give or take 20$. Aftermarket LED's are all chinsese made crap that'll burn out in months, then you're taking apart the bezel again, clips etc....to replace LED's forever..
erinobr2000
