*****CLOSED***** 3rd Gen Drifter Mount for CB Antenna
It doesn't appear my Scobra did, but I am sure it is something I can pick up some where. I'll let you know if I am interested.
I used to have a Cobra Roadtrip if that helps. I had an adapter, and I think it was something like an HA-BNC adapter. It fit on the fixed antenna output on the Roadtrip, and converted it to a PL259.
[MENTION=146075]DirtTimeAttack[/MENTION], you will need one HA to BNC adapter like MStudt mentioned, this will convert your handheld Cobra's little antenna mount to mount that takes coax. They are about $8.
In Addition, you will need the following.
1x Firestik II, your choice of length and color. I suggest 4 or 5ft units.
1x 18ft Coax Cable
1x Firestik K4-A Stud Mount or SS-34AM Spring/Stud Mount if you want the spring.
All of the gear including the Drifter Mount from [MENTION=98153]MStudt[/MENTION] will run right around $120 and will greatly improve the range and clarity of that little handheld, while laying the ground work for a future radio upgrade if you decide to go with a bigger unit.
HA-BNC
prod_41225803
I've only got a couple mounts left, and they can be bent for either side. Once these are gone I won't have anything left, and no ETA on the next batch.
Mike
Alright people. At this time I only have 2 mounts left, and both are driver side mounts. I have 1 that I'm selling for the normal price of $60, and another mount that I'm going to sell for $50 since it's a blem.
wayblom
