Clunk Over Bumps
I have a mystery sound as well. I've captured it on video. It only happens when I start moving. Never notice it at high speed. Happens driving straight or turning. Listen at second 10-12 and 28-34 of video. Thanks.
You tube video: https://youtu.be/Rc4Al5Qrj9s
Same sound, and my upper ball joints are leaking like a mother****er
Sent from my ZTE B2017G using Tapatalk
My nocking noise is coming from the rear, and seems to be that my rear right shock has lost the nut on the top of the shock. Causing the shock to seperate from the body mount, and cluck when they come in contact with each other again.
Clunking sound going over bumps
I have a 2008 SR5. The clunking sound coming from my front end turned out to be due to the front stabilizer bushings. The sway bar is supposed to twist while seated in the rubber bushings but I think the rubber became less supple and was gripping the bar too much and not allowing any give. I replaced the bushings with new ones but probably could have just taken it apart and put some silicone grease between the bar and the bushing and solved the problem. Easy cheap fix. FYI the bushing bracket clamps are marked left and right.
AndiGarage
