Clunk when steering
tylrdvs277
Hey all,
Looking for some help diagnosing this issue. This seems to happen mostly when when moving. Basically when I turn slightly off center to the left and then turn back right again I can feel a clunk through the steering wheel. This doesn’t happen when I turn back left after turning right. Any idea if there is some component I should take a look at or does my steering rack just have some play in it due to its age
You can check your steering components with a jack and a pry bar. Place the jack under the lower control arm and raise the vehicle until the tire is off the ground enough to get your pry bar under it. Make sure the vehicle is stable on the jack. Place your hands on tire at 3 and 9 o'clock and push and pull on both sides. Any moment here wound be steering linkage/gear or wheel bearing. If it is coming from the steering linkage you can isolate by holding the tie rod while pushing/pulling. Prying up from under the tire will check the ball joints. Pushing/pulling at 12 o'clock will check the upper ball joint and wheel bearing.
Last part that clunked in mine was the intermediate steering universal joint shaft. Was about $180 from a dealer for the whole part even though just the U joint is bad.
A little bit of a pain to put on only because the splines get seized together, but some hammering and it's off.
A couple bolts in the engine bay and a bolt or two under the steering column.
+1 for intermediate steering shaft. Mine went at 190k. You can try spraying some lubricant on the u joint and drive around for a bit. If you don't feel the clunk or feel it less, that's your culprit.
I would also look at the intermediate steering shaft first. If in the past you had hard notchy steering then that would be the first step of it wearing. Worn inner or outer tie rods can also give a side to side clunk. Best bet is with the key on and engine off, have someone turn the wheel side to side a bit so you can listen for clunks. When you have the area the noise is coming from to focus on, you can often see the loose part.
are you only able to reproduce when moving? Or will sitting still in the driveway cause the same noise? if you can reproduce it in the driveway my suggestion would be to have some one steer it for you while you look and feel around. Otherwise, I would likely start with the intermediate shaft as already stated, but balljoints are also very likely to clunk during steering as they start to wear. Assuming you're on factory lower and upper arms?
Thanks for all the input everyone! After posting this, I took the truck to an alignment shop. I let them know the issue. They did an inspection and aligned it. They told me they saw no issues with the control arms, ball joints, tie rods, etc. and they too thought it would be in the steering somewhere. I got the parts and I’ll replace the intermediate steering shaft and see what happens
Outer CV axle joint. Check for lateral play.
