Code 0420
kameleon
Junior Member
When I got my '00 4runner a little over a month ago it has code 1130/1135 which meant the front o2 sensor. I replaced it and that code has gone away. Now 3 times within about 200-300 miles of each reset I have gotten code 0402. I see that could be the rear o2, cats (it has a cali emissions), or exhaust leak. Before I go spend $65 on the new rear sensor is there wa way to test the rear sensor? I read somewhere, that I canot find now, to hold the rpm around 2500 and watch the voltages of the two sensors. However I cannot find where I read that again nor can I remember what the voltages should be. I have an elm327 bluetooth odb2 adapter with torque pro so I can monitor all that stuff.
Sorry, yes 0420. I'm not too sure about pulling the cats and soaking. I guess I could do that if the rear o2 tests good though. Just sucks having to pull both cats. Thanks for the info.
Actually, there is not much point to an ohm test for a P0420. The ECU does that test continuously, and if the sensor is out of spec, it will give a different code (P0141).
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/di/eg5vzfe/cip0141.pdf
That said, a sensor can still degrade and be responsible for a P0420 without being out of spec on heater ohms, although you will find techs who deny this. I cured a P0420 by changing my rear O2. It had 110k anyway so it was time--I didn't sweat the diagnosis.
It threw again this morning. So since today is pay day I will be ordering a new rear o2. Hoping this fixes it. If it does then I can move on to suspension/steering issues. :)
