Coil spacer on driver side only?
achha64
Hey
I want to use a 1,5 inch coil spacer on the driver side spring to make it equal height to the passenger side. Is this will not cause any problem? Will I need to align this after?
Hey
Should work. I plan on doing the same once I get new coils installed. I've found "RRO toyota trim packers" that are 10mm in width. I saw a review where 2 were used to raise the drivers side about 3/4 of an inch.
I have 1.2 inch exactly of different between the driver side and passenger side. (When car is empty) I have a LC springs on the rear.
brushbuny
