coilover length
berettashot117
so ive got the toytec ultimate lift with 285/75/16's, and as expected I had some rubbing issues. I trimmed enough away to where it only rubs when I hit a bump while turning (ex. turning into my driveway). I've pondered about installing a 1 inch BL to solve this problem completely. however, I was looking at my coilovers today, and I notice it looks like I might be able to adjust it and raise it up a little bit higher. can anybody tell me if it's as high as it can go, and can I raise it a little more, hopefully solving my rubbing problem without the BL. thanks for any help
How much over stock is your current lift? Where is it rubbing? You can lift your front up to around 3.5" over stock height. Anymore then you'll be stressing your CV joints. If you're rubbing on plastic then just trim more. If you're rubbing on the body mount frame then its time for a body mount chop. No amount of body lift will help you there.
Good luck, I know how annoying the rubbing can be.
freddygino
