Common problem with projector retro? Or just me?
What I did was tighten them with the glass lens off and I held the projector in place with my hand until I got them snugged down. Then I plugged them up to check the cutoff and to make any small adjustments before I put them back in the oven.
great I have to bake them again...........
If you don't want to bake them again, this might* work:
(I don't know if the proper thread and size nuts are available but assuming they are)
(Also Assuming the projectors are properly aligned)
Mark them to the housing with a Sharpie.
Get two nuts in the proper thread size and lock them on to the threading of the projector.
Then using two wrenches tighten the lock ring while holding the projector in place via the locked nut.
*This could also be a pointless waste of time and effort, I have not tried this just an idea that came to mind. Its similar to adjusting a bicycle hub bearing
Really?
Does that mean the BI-XENON MORIMOTO MINI STAGE III KIT (H1) from TRS is an easy retrofit on a 2000 4runner?
Yes. The Morimoto mini H1 and D2S kits are easy to install.
You just have to cut these things off.
<a href="http://s68.photobucket.com/user/justwoody1/media/headlightmod.png.html" target="_blank"><img src="http://i68.photobucket.com/albums/i31/justwoody1/headlightmod.png" border="0" alt=" photo headlightmod.png"/></a>
huh.... and to think i spent an entire day dremeling, drilling, screwing, and gluing (epoxy and puddy) 2 headlights.... well i guess that's the whole "work smarter not harder" thing isn't it..... :redbrick:
[MENTION=73787]SantaCruzRunner[/MENTION] did you ever get the bounce fixed? Mine have started to do that as well, I think the nut is loosening up over time. Curious as to how you fixed yours.
Deelock
