Sorry....I meant to say the rock lights. SMH. I have since moved the SwitchPro to my 2021 and I moved it to the top of the panel to left of steering wheel. Mounted it with 3M tape and drilled hole for the wiring. I like this location much better. I know SDHQ makes a replacement panel specifically for mounting the SwitchPro in this location, but it is not needed. It is way over priced. And if you remove the SwitchPro a replacement panel from Toyota is only $40.
Hi [MENTION=4307]matoolie[/MENTION]! If you catch this was wondering if you can sort me out. I have received all the components to make this happen and now I am trying to map it out by looking at your pic. My brain is frying matching up your pic to your circuit drawing.
Questions:
1. Pin 2 from the SSR is the green wire with the diode inline which goes to pin 86 in the drawing but looks like it goes to pin 85 of the mechanical relay? I believe you can reverse those two with no issue but did you wire to pin 2 to 85 or 86?
2. Pin 2 of the SSR the cap is wrapped between post 2 and post 4 correct?
Not sure why the pic isn't posting here but here is the link for a your picture I modded:
https://freeimage.host/i/HUQTAdX[/IMG]
Bonus question...
Looking at how you designed the 2 relays, can I take the trigger output of the SSR and also use it in the exact output with the diode and connect it to a second mechanical relay which would also work the same, use the trigger and switched 12V power (not using the puddle circuit power, only want the trigger. Example - trip the puddles, it can turn on the rock lights AND with the other trigger, activate the other relay to turn on power for footwells/cargo lights. I would also be able to trigger the footwells/cargo with a manual switch. Have i lost my mind or is this not an issue?
