coolant temp sensor
SAYWHAT
Gauge doesn't move from cold at all. Does anyone know where the temp sensor is located on the V-6?Put a scanner on and reads 200 warmed up. Could the problem be with the dash gauge or wiring? Thanks
Id check the sensor for the gauge first. Is at the very back of the motor. Located in the coolant passage under the heater hoses. It has one wire going to it.
I can not locate it at rear of engine (firewall end of engine). Have read another post that says there are two sensors, one digital for ECM readings and another one which feeds the analog dash temp gauge. Have found what appears to be a temp sensor at front of engine (radiator end of engine) passenger side of radiator hose with 3 wires , possible it is the digital one.
edit
sensor at radiator end of engine has 2 wires (not 3 ) about 3 inches long coming out of it then a connector.
Autozone shows the sensor with one spade terminal connector.Cannot find the location at rear or front of engine!Really need to get this fixed.The 4runner is a 1998 3.4 v6.Thanks
I've not yet replaced or worked on my ECT sender gauge, but it's on the back of the engine on the passenger's side, I believe.
FSM Zip File for Download (23.6 MB)
The link provided is from the 3rd Gen documentation page (might want to save it).
Look at pages 1507 and 1520 and in between for info on how to replace the ECT sender.
If you were considering getting a Scangauge 2, now'd be a great time: You can read the water temp in degrees C or F, live as you drive.
Here is what you need to be looking for:
WaterTempSensor.jpg~original
Replaced mine a few months ago....just a little bit of a pain, but not too awful. Picked the new sensor up at my local dealer for about $45. As I recall, you have to disconnect your rad. hose, remove the front "3400" engine cover, and then remove the fuel jumper rail. Basic socket set (make sure you have a 19mm socket!), a torque wrench, and your hand tools will get it done in an hour or less....biggest two things are 1) to make sure you torque the new sensor to 14 ft/lbs and the jumper rail to 25 ft/lbs. and 2) to get new crush gaskets/washers for the jumper.
This also is an excellent time to change your coolant :biggrin1:
Edit: Also...while not necessary, a set of crow's foot wrenches will be a huge help. I picked up a cheap set from Harbor Freight just for the job. I thought they'd be a one-use thing, but they've actually been handy for several applications.
found it
FSM lists 2 sensors, one is located at front of engine next to the fuel rail cross overpipe ,this one goes to the computer.The second one tells the dash gauge the temperature, location not supplied by FSM.It indeed is at rear of engine as some have correctly implied,the main engine wiring harness is directly over it and surrounded by heater hoses and vacumn lines.I have only seen it thru a mirror! Thanks for the help
The front one is not to bad. The one in the back of the intake is a pain in the ass. Or at least it was for me.
Blue
