Cornfed installed on 2006 SE
Trik444 said:
PS - I have XREAS and the tech didn't mention anything about having to mess with the system when he installed the spacers.
Just be carefull when you do the front struts. Best of all do not remove them from the wheel well, just unmount and do the install on the place.
dararith said:
i'm going to go w/ the 3/2 cornfed lift - did you have to do anything special to work around the x-reas system during the install? my biggest concern is accidentally messing up the x-reas. thanks for the great thread...
Everything is in blold print in the instructions that is important. You just don't want to disconnect any vacuum lines and you'll be fine.
http://www.burtmanindustries.com/zoomprod.php?id=4run_03_up_liftkit
DionicioLives
