Correct wiring harness for a 2004 JBL non Nav
cdoyle
Member
Hi,
Been trying to figure out which harness I need to update the stereo and not have to cut any wires.
2004 Limited, with JBL non nav
Behind the headunit I see 3 plugs.
I have a Metra 70-8114 which is supposed to be for the steering wheel controls.
Is this the correct one?
Which part #s do I need for the other ones? Metra's site listed a 70-1761 but that's totally not correct. Wrong size all together.
I believe I need a 70-8117, but before I spend any more money, is this the correct one?
Check Crutchfield.com. They’re really good about adding on the correct accessories.
If you already own a head unit, you might need to load your vehicle and put a head unit in your cart for them to suggest the correct harness.
What you need with be the 70-8113, or could be you need an interface which would be the AXDI-TY1. It's an amplified harness. You might not have JBL but it means its still amplified, just not with the JBL Digital amp which would require the AXTO-TY1. The 70-1761 is for basic audio which you just mentioned is not it due to the harnesses not lining up. The 70-8117 is an amplifier bypass harness.
I have used Crutchfield's for this type of info. If you enter all your info it will tell you every adapter and trim kit required for a plug n play install. If that is where you got the incorrect harness number call them and they will look it up and verify the correct parts.
NCH
delislerebecca
