OCMEDIC
I have always been curious what the easiest method was for correcting driver side lean. Before I got my CBI bumper and just had my radflo front and rear set up if I took a tape measure and measure from the top of the tire to the fender in the rear it sagged about 1 1/2 in on the driver side. Now after I having my bumper and all pro 3.5's installed it still leans on the driver side but only 1in. I'm curious what the easiest way to correct this is. Previous to having my all pros installed I had been messaging [MENTION=65653]aha2988[/MENTION] about running a daystar 1.5in spacer under the driver side rear coil but for some reason the mechanic had a problem with me doing that and I took his advice and held out. What I would like to know is, is that my best option to run a spacer under the driver side coil or could I correct my cranking up the driver side coilover in the front up? I would really appreciate some input, thanks.
