Cougar House Garage 17' 5Th Gen Limited 4Runner Solid Axle Swap Build
Thats what we did today keep in mind we need to make some pedestals to put under the jack stands to get it to ride hight tomorrow we'll design the radius arms
The air_lift_performance Dominator D2600 bags showed up at cougar house garage today form switch suspension for the 5Th Gen 4Runner SAS build, these bags are awesome with unprecedented maximum restrained pressure of 600psi and a max load rang of 3055lbs per bag, I'm excited to get them mocked up on the Cougar House Fab 5Th Gen 4Runner/3rd Gen Tacoma sas 4link kit Monday
Do you have an estimated lift height, with the size of that radius arm bracket it looks like it's going to be huge.. like dropped transfer case huge.
You can lift a Ford Super Duty an a Dodge Ram really high like 14'' to 18'' lift and 40's just fine with out a drop adapter and dope case, the 4Runner is no different :thumb3:
Cleaned up the garage today while we wait for the new hand held controller for the CNC plasma table to get here on the UPS truck Thursday
Hous many inches forward are you moving the front wheels? Looks like a pretty good amount. I wish someone would design a front ifs knuckle for these trucks to shove the wheel 2" forward...
feel like fabbing me up a sheet metal knuckle?!? Lol
Ok, so do you have an estimated lift height? I understand if you're building it as you go because there's a lot of custom fitting going on, I was just curious if you had the numbers figured out since it looks like you've got the links mocked up.
Does D4-D mean that 4cyl? I hope not.. Can't imagine that being enough power for 40s.... unless the turbo was upgraded and the boost was at the absolute limits....
Will be curious to see how it comes out either way.
No turning back now LOL
So back in the day I had a 4 cylinder Pick up on 44's, 570 gears and Steel wheels as Aluminum wheels were not that easy to find (yes I am old). I put over 75,000 miles on that truck and never had an issue on the highway. It was a 4 or a 5 speed can't remember and I just never needed to use 4th or 5th gear.
So yes it had plenty of power to move those tires and it even had plenty of power to do the Mud Drags at Union Grove Drag strip almost every weekend.
ps. Seriously we need more pics and I love your 3rd gen !!!
and this truck is bad ass
seltzernator
