Couple Questions
cpayne5
Does the overhead console (front seat) just pop out? Just the little plastic section with the lights, not the entire headliner. Also, is there a switched power supply up there that I could tap into? I want to install an XM receiver in the glasses flip down, but would like for the unit to turn off when the car turns off. I have a sunroof, if that helps.
Any insight would be great. I've got a Scion HU coming this week and would like to do this all at once.
--Chris
Chris,
Yes the console does come out. Just wedge your fingers between it and the headliner up by the windshield and pull down. Its held in by a couple of clips. As far as power, you could probably tap the sunroof power as the map lights won't cut it.
Someone here has done this already, do a search on sunglasses and XM or something.
ZonaT4R said:
Chris,
Thanks. I figured it just popped out, but didn't want to try it till I knew for sure. I'll probably tap into the sunroof power, if its easy to get to.
Again, thanks!
--Chris
OK, thought I had big trouble, but it turned out to be small trouble. I pulled the console out like suggested, but the little metal clips popped off the plastic pieces up into the roof! Actually I didn't even know they were missing (or even existed) until I tried to put the thing back up in the roof and it kept hanging down. I then read on here were there supposed to be clips. So, I fished them out (very tedious :D).
I now need to know how they go back on the plastic stubs. Anybody have a picture of their assembly or know of a place where I can see a drawing of how it goes?
Thanks.
--Chris
FoxyMama
