Cover me, I'm going in...
Pick_T4R
Backstory here
I have a knock sensor issue and I'm going to try to do it myself. I'm not a Master Mechanic but like to tinker on things. I've watched a few YouTube videos (that makes me an expert, right?? :rockon: ) and I think I can pull it off.
My question: What else should I do while I tear it down? This is not a DD but I don't want it to sit for months either. Ideally, a couple of weekends would be perfect. I found a timing belt/tensioner/water pump kit and think I will do that as well. Should I have the heads done? Block/pistons?? I don't know any machinists in my area so would need to research that if that's what's needed. It definitely has a small oil leak somewhere that I'll need to address, hoping that's valve covers or something cheap/easy.
Any comments on www.yotashop.com? Seemed to have reasonable prices on OEM/Aisin parts.
220k miles on the truck & bought it for $2k; really don't want to put another $2k in it but don't want to cheap-out either.
If the engine is not burning oil I would not bother with a rebuild. Focus on repairing the problem at hand. I would send the injectors out to be cleaned / balanced. All new o-rings for the injectors and intake manifold. It wouldn’t hurt to replace the intake gaskets between the lower intake and the heads. Maybe the rubber coolant lines that would be difficult to reach at the back of the intake. It’s common for the knock sensor harness to become brittle and fail.
2001ATL
