Crap - Evap codes
alms_lefko
Check Engine, VSC lights etc
P2401
P2402
P2419
from what I've researched I need a new charcoal canister? $400... ouch...
Anyone get those codes and have a fix without buying a new charcoal can?
P2401
P2402
P2419
I'm in the same boat as you...looking for a local decent non-dealership mechanic. From my forum reading, a good mechanic can troubleshoot to make sure only the required evaporation system parts are replaced. It could be hoses or solenoids that need replacing.
I did see a YouTube video where the charcoal can is taken out, wb40 is sprayed in the inlet and outlet of the can (it's sealed and can't be taken apart without damage) and left overnight. He then used compressed air to test the can and got air to flow through.
Fortunately I have until July until my emission testing is due so I have some time to find a good garage.
Cheers!
P2401
P2402
P2419
Try a new gas cap first. Some of those evap codes come on when the gas cap doesn't seal tight enough, which happens over time as the cap wears a bit.
FYI, the charcoal canister can fail when you add too much gas to the fuel tank on a regular basis (topping off after the gas pump has already clicked off). Toyota recommends filling until the gas pump clicks off, then tightening your gas cap 3 clicks.
I never fill past when it stops.
I'll try a gas cap first and see. $10 is worth it for a test.
Good, I hope for your sake it is just the gas cap then.
I had this issue when I bought my 4Runner at ~75k miles, although I think I pulled different codes, so it may in fact be a problem with your charcoal canister, or the leak detection pump housed within.
http://www.toyota-4runner.org/4th-gen-t4rs/23768-here-malfunction-codes.html
As much as $400 will suck... I look at it as I don't put ANY money into this car cause nothing ever 'breaks'!
I'm at 145k miles now
P2401
P2402
P2419
You did not mention what year or engine your vehicle has.
Are those the only DTCs you have for the vehicle? Just those three?
P2401- Evaporative Emission System Leak Detection Pump Control Circuit Low
P2402- Evaporative Emission System Leak Detection Pump Control Circuit High
P2419- Evaporative Emission System Switching Valve Control Circuit Low
These have NOTHING to do with the gas cap at all, there's a different set of DTCs that set as a result of the gas cap being loose/leaking. These DTCs refer to conditions inside the EVAP unit itself. There is a TSB that describes a possible faulty EVAP assembly for a subset of 4th gens, but the criteria is that 5 DTCs are set.
View attachment T-EG040-06.pdf
2005 v6 with 145k miles. I did resettle CEL and drive 20 miles. Hasn't come back yet...
Had 5 codes but my crappy $20 code reader couldn't decode the first two. It said NA for them.
Looks like I'll beyond a new assembly. Easy enough to replace?
Sounds like the canister assembly is faulty, I imagine the other 2 DTCs will fall under the TSB as long as your Year/VIN also fall under it.
What state is the vehicle operated/registered in? You may be covered under your state's emissions or the federal emission's warranty; I found this:
http://www3.epa.gov/obd/pubs/420f15035.pdf
If you have an extended warranty it should be covered depending on your policy terms.
Florida... We don't have emissions. :guitar3:
Cleared the codes and all 5 came back. No CEL or VSC lights - but all 5 are in the ECU.
Question - when the VSC lights and all come on is that just a signal that something is wrong with the EVAP system, or does it also mean the VSC etc is no longer operational until you fix the problem?
Is your 4runner starting and running well? are you still getting good gas mileage? If the answers are yes, why dish out $400 just because some computer put these codes from the check engine light.
I got a check engine light around seven years ago on my 98 Nissan Maxima, codes were for needing new O2 Sensors. It started good gas mileage never dropped. Covered the panel check engine light with black tape, been driving it everyday and it's still going strong.
Yes... But I want to fix it because I want my VSC to function...
What does the codes have to do with the Vehicle Stability Control (VSC)? A Charcoal can that absorb fuel fumes check engine code, will keep it from working?
Have you even tried engaging your VSC?
I don't think that the 2005s had the option to turn it on or off. My 2004 doesn't.
It has NOTHING to do with the VSC or related systems, But Toyota chose to disable those systems when a CEL is activated by some fault. Pain in the arse but that's the way it is so it has to be fixed or bypassed somehow. I had an ongoing fault that I had to clear every startup with the Ultraguage. Finally have that issue rectified.
fhgy0045
