Crawford Eco Block
I hate to bring back this thread :hiding: :behindsofa:
But I just thought of something...
This device works by positioning the MAF where it sees less airflow, right? Doesn't having a dirty MAF sensor have the same effect? A dirty sensor is insulated from airflow by dirt, so it gets hotter and the computer thinks there is less airflow than what is actually there.
There are claims that this device improves MPG and that cleaning the MAF improves MPG. Can they both be right? It seems like a contradiction to me.
Your thought process is correct, but the term dirty is hard to put a percentage to.
I will tell you what. You send me one for free and I will run on my torque pro with my 2011 stock sr5. I drive about 4000 miles a month. I know what I get out of every tank. I can use for a full month and give a real world review. I currently get 20.5 miles to the gallon and I know how to cheat the pumps and my tank to make sure it truly fills up. I can watch intake temps and also my mav gauges to see influxes. Its your call if you want to sell these things I will help you out with putting this to the test for real. I drive from Philadelphia to Baltimore at least 2 times a week. The most I got out of a tank was 500 miles keep in mind that was drafting 18 wheelers from Philly to Pittsburgh. Just this week I got 470 miles out of a tank driving to Corning ny.
I average 430 miles to a full tank. By the way the most amount of gallons I have put in the truck is 25.5 gallons. I usually am putting 22 gallons every 2 to 3 days. I will even check plugs each week to see any dentation problems.
YOUR CALL TO END ALL OF THIS MADNESS. pm if you want.:50cal:
Can this madness end this easy?? Maybe I should buy you a few tanks of fuel as well :) The haters will never stop hating... it's ingrained into their blood.
Send me your address and we will gladly send you test unit. Thanks for reaching out with this offer!
I'll even help out. If [MENTION=75851]flounder1[/MENTION] will agree to send me fuel fill ups, odometer readings and dates to me I will track the data and put them into a usable format with some type of trailing average over time. Run without it for a month, plot the data and superimpose the following month's data with the spacer installed. I will publish here. This would be strictly an efficiency comparison.
OK, so it's been a while since [MENTION=75851]flounder1[/MENTION] got his free eco-block that [MENTION=121742]Quirt[/MENTION] sent him, [MENTION=66316]1engineer[/MENTION] volunteered to diagnose & dissect data supplied from 1000's of miles of before and after the eco-block install.
Bottom line, what is/was the outcome from the data, if any?
Thousands are awaiting the results...........:whip:
just sayin'
just sayin'
Testing is taking place which takes time, hang in there.
FWIW, to calculate a statistically relevant result, the sample size should (based on my records of my driving std deviation), 64 tanks of gas. My 4runner isn't even close to 64 tanks of gas since new so I can't say with any confidence what my mpg even is as a baseline yet.
The end result is that someone would need to do about 25,000 miles of driving with this before we could have enough data to say with a 95% confidence that there is any measurable improvement in MPG.
The point: it's going to be a while before we know anything.
Cross posted from my build thread but it should be in both places:
Sooooooooo....
Remember that Crawford Eco Block MAF spacer thread a bit ago?
Ok, I'm not an idiot. We'll not so much these days, I was when I was 20 of course. I got scammed good at the swap meet with a "Spark energizer" thing that you popped onto the top of your coil to "Increase the intensity of your spark" to get better gas mileage. The guy had a car there and everything and would pop the thing in and out of the car while it was running and it ran great when in and not as hot when out.
Turns out he was standing on a piece of carpet with a switch under it that would cut out half of the plugs when he stepped on it making the engine run like crap on command.
Serious life lesson learned!
So I'm super pessimistic of EVERYTHING (Just ask anyone!). Intake cyclone? Gimmie a break, Fuel Shark? Is anyone THAT stupid? Etc etc etc...
Ok so the Crawford Eco Block MAF spacer... Here we go again... Only.. after reading everything I could about it and just relying on my general knowledge on the way the world works, both from an engineering and from a "Everyone is a scam artist" angles. I decided that there just /might/ be something to this.
So I quietly bought one a few months ago and gave been testing it. I've just got enough data to give what I think is a pretty solid test result.
I have a very strict set of habits when checking my MPG. I always gas up at the same station and usually the same pump. I always gas up just before and just after a trip so I completely separate my daily commute from any large outings. I'm a generally mellow driver, though not a hyper-miler.
For these results I averaged out my MPG only for completely full tanks and ONLY for 100% normal commute + weekend errand driving. Trips to the desert/Utah etc have WAY too many traffic/weather/random gas station variables to be very accurate.
Also, as an FYI, I live at nearly sea level and in California there is not really much if any of a summer/winter blend any more. It USED to be that in summer the MPG went DOWN because of anti-smog additives, but we get those year round now. So there is no big mileage drop/boost from winter to summer here any more like there used to be.
The numbers:
Completely stock
I only went through maybe 3 tanks completely stock and I didn't save the numbers...
Lifted, 265 (stock size) Toyo AT2 tires (Covers an 11 month period from April 2014 to March 2015, no Summer/Winter gas issues at all)
18.06 + 18.78 + 18.69 + 18.58 + 18.81 + 18.38 + 18.53 + 18.97 + 18.71 + 18.48 +
18.33 + 18.86 + 17.89 + 19.41 + 19.65 + 18.58 + 18.02 + 18.42 + 17.79 + 18.27 +
18.63 + 18.22 + 17.93 + 18.48 + 18.08 + 18.03 + 18.26 + 18.61 + 18.38 / 29
18.476
Same as above but 275 BFG KO2s
16.8 + 17.66 + 17.31 + 17.18 + 17.66 + 17.51 + 17.38 / 7
17.357 - 1.119 MPG
Same as above but with the Crawford Eco Block
18.15 + 18.21 + 18.66 + 17.92 + 18.27 + 18.45 / 6
18.276 + 0.919 MPG
Results
* 1.1 MPG drop from Stock AT to 275s
* 0.9 MPG increase using the MAF spacer with all other variables constant.
I was already as light on the pedal as my Patience would allow with the 275s knowing they were sucking my mileage down so there was no further room for pedal shenanigans with the spacer in.
So given where I drive and how I drive, those are the concrete numbers. The results were immediate and consistent, both for the tire change AND for the MAF spacer install. I'll pay for itself after about 5 months for me, and after that it's like getting a free gallon of gas with every fill. Not too bad.
So what about more power?
While I believe the dynos which show a + 5 HP across the range, I absolutely could not feel a thing on my first drive after install. The % gain in HP is just too small for me to notice.
What about mileage on trips or offroading?
I have no idea and may never really know... For example though I only lost 1 MPG going from 265 to 275, that is only for my mellow daily commute of 50 miles. When going heavy throttle out up a mountain, or if I had a lead foot, the loss could be more like 2 mpg as others have reported. My daily commuting is so utterly consistent but the gains, while there, are small enough, that I don't think even if I drive to Utah twice a year for 5 years if I could tell if I got better mileage when driving all out than before given the HUGE variation in MPG per fill up on my last three trips due to traffic, weather, energy level etc.
In the end I'm pleasantly surprised and quite happy to have nearly eliminated my 275 oversize tire penalty and will likely make going to 285 at some point less of an MPG disappointment ;)
Addendum: As per [MENTION=118321]Jetboy[/MENTION] s post above. Since I have eliminated most of the variation in my measurement technique, 64 tanks of gas are way WAY more than are needed for a confident result.
A this point probably 10 samples would be at 99% accurate. But yes, if I were just using every single full and partial fill as well as every crazy thing I take my truck out on then it would take FOREVER to get a fine enough measurement considering the huge 9 to 23 MPG swing over every single entry in my log.
I reduced a +- 50% swing in bare stats to around +- 5%. Concentrating on the majority of my driving which is my daily commute and the thing I'm most concerned with. I don't care at all what my MPG is offroading :D
I appreciate all the work people have put into verifying this.
So, it's $40. I normally get about 16mpg driving around town with the 85% gas and full time 4wd. If I got 17mpg, how long would this take to pay for its self.
My normal fill-up is 20 gallons ($2.50/gal) and that gets me 320 miles at 16mpg costing me $48 giving me a ratio of .0625 cents per mile.
If this block increase my mpg by 1 I'd get 340 miles for the same $48 giving me a new ratio of .0588 cents per mile for a difference of .0036 cents per mile.
The result is 11,111.11 miles till you break even.
It's been a long time since I did math in public, but I think in your example the break even point is 4533 miles. At 16 mpg, you're paying 15 cents per mile. At 17 mpg, that drops to 14.12 cents per mile. The difference is 0.88 cents per mile...divide $40 by the difference and you're just over 4500 miles.
Unless I also screwed up the math, in which case all bets are off. :)
LOL! I like this. I always double check my work, specially when posting publicly.
BTW, send over some of that $2.50 gas this way...
Interesting discussion going on Tacoma World about the Crawford Eco Block. Crawford performance has people posting in the thread, giving explanations, logic seems sound. I think I'm going to call Crawford on Monday and order one for my wife's '13 4Runner...
Eco Block from crawford performance - Tacoma World Forums
David
This is bullshit.
If you want to waste your money, send it to me.
I'll email you photos of my fun weekend with two escorts in Vegas.
I did.
I'd say it's within the standard of deviation and what's expected for an engine once it's more broken in.
Not THAT is probably the biggest load of bullshit in this entire thread.
There is NO WAY that there could be a random and steady full MPG drop or gain at the INSTANT and for the FULL DURATION that one variable was changed, let alone TWICE, unless that variable caused the change.
Or are you saying that the switch to 275 tires doesn't really lower gas mileage either? And that my numbers above don't show that? Cuz that would be pretty big news to the entire wheeling community if it were true.
Be skeptical (And no one is more skeptical than me) but keep an open mind!
Unless of course you are just another internet troll, I was taken in once this week already on this forum, my troll sense is not highly developed I'll admit. :(
If it helps, I think your results are legit. Seems consistent with what other have seen with it also. 1mpg is not huge, but it is something.
Heh thanks, yeah I got a little hot there. :( My apologies to the thread...
Well we'll just let the readers decide who they believe at this point.
Yeah, I'd say the gains are.... Just barely worth it, could be more or less depending on the person. Maybe not worth it for some people who get super cheap gas, but I just paid over $4 a gallon again today so.. I'm leaving it on! :D It's like $4 cash back every fill up!
Glad you're happy with your purchase.
What is your reckoning of the significant stdev decreasing with fewer data points (this is counter intuitive to a 'controlled' sample)?
What tire pressure over the trips?
What temperatures and barometric pressures?
What distances per fill-up (if you fill up in 10 mile increments vs. 400 mile increments).
If you were to remove the ecoblock, would you expect a .919 mpg decrease (you could test this while keeping "everything else the same")?
What are your O2 sensors reading before and after the ecoblock (you can buy an OBD2 adapter for a smart phone and record this data for less than an ecoblock)?
Actually after eliminating partial tanks and any tanks where I'm driving over the mountains and offroading, the deviations are amazingly small... Also, I'm keeping the spacer on for the time being so I'll eventually have many more data points for the third case anyway...
Tire pressure the same for the second and third measurements. And though the actual lbs were different between the Toyos (first set) and the BFGs (P-Metric Vs LTE) the relative tire pressure to maintain proper load and footprint was as close as I could make them. In fact I could possibly eek a bit more MPG out of adding another 5-10 pounds to the BFGs, possibly another experiment, it certainly wouldn't go down any more :) The Tire pressure between the send and third sets was the same, 44lbs.
Living in San Diego, the weather here is remarkably constant compared to other places. You can see through the entire 11 months of the first set that there is virtually no change at all through summer/winter and the variations are remarkably small and I think mainly due to the variance in my weekend driving which is all low MPG city stuff. I.e. if I don't drive on the weekend I get closer to 19 mpg, but if I make 5-6 trips its closer to dipping below 18.
Full tanks only. Short fill ups are problematic due to higher noise level in the calculation and having too much "weight" when averaged with full tanks. The numbers above are for full tanks only.
I would since nothing else changed, maybe after gathering another 6-8 good samples I can give that a try.
Sadly one thing I did not properly prep for was that and measuring the external temp of the headers before and after :/ There is the remaining question of how this might be affecting the engine itself over the long term.
In the end my /feeling/ is that it's not likely to be too much due to the relatively small change in A/F mixture. But yeah, I do wish I had gotten some before and after readings of the exhaust profile to know what was going on there...
I do have an ODB adapter. I could get readings now and save them for when I try the removal test in another 3-4 months or so.
This is bullshit.
PM me info on these escorts please.
1) Delete MAF
2) open source tune
3)
4) profit
:gun5:
Anyways.... coming from a performance/built platform I can see both arguments here. This is essentially a phenolic spacer for the MAF. Any time I touched my MAF I adjusted AFR to reflect. MAF/AFR are intricately intertwined on motor performance and when you change a small variable you can inadvertantly cause harm to the motor.
I don't know if the pistons are composit or cast/forged in the 4r but if they are anything like the newer vehicles being released I would say STAY AWAY unless you get a vehicle specific tune. This product seems to "trick" the MAF into allowing adjustments for increased power... but are you tying adequate fueling? Are you logging AFRs at idle and WOT? Get this with a tune and you may see better results.
I won't get it but if you get it and are happy then I am happy for you :) post some logs so we can see your results
Someone else would have to try this as it would need some separate equipment I think.
I have looked at the AFR graph while driving, and it shows.... a perfect 4.7 AFR (With deviations for short periods of acceleration deceleration) just like before.
But of course, the ECU /thinks/ it's putting enough fuel in to hit 4.7 but... since it's MAF value has been tweaked by 5% (or whatever) it's putting in 5% less fuel to hit that target and then seems to be reporting that value through the OBD port. So I'm not sure that AFR value is an actual reading as much as it is a statement of intent by the ECU.
I would be interested if someone did an analysis of those issues that has the proper tools and knowledge to measure actual values separately from the ECU which is being tricked. That part is a bit beyond me I'm afraid :D
What scares me more are the people that buy used super chargers and slap them on without going in and getting their ECUs reprogrammed to handle it. Yikes!
seltzernator
