crazydubman
Active member
Sounds good drew
let me know when you do the tranny cooler cause i need one to!
I'm ordering up the cooler tomorrow. Going with a B&M 70266 from Jegs. Figure I will be into the whole setup about $100. I want it taken care of before Pismo. Bumpers come next week so I can take care of the cooler at the same time while the front end is apart and easily accessable.
Should be ordering up the Poly steering rack bushings as well through Wheelers to get that taken care of also.
I'll hold you too that.... hahaha
I may be able to swing that. I still have the boxes so it would be an easy ship option. They are 16x8" 4.5 BS. They ended up being the perfect offset because i rub a little on the frame at full lock in the rear and on the pounded firewall and rear of the front fenders a little with the 305/70/16's. Any more either way and it would have been even worse trying to get them to fit with just a 1.5" topout spacer lift.
and I meant late next year. My tow rig will be getting swapped out from my 06 runner to a 97 Powerstroke after the wedding when my fiance gets another car. Looking for another set of the hutchinsons for that one so I can run the MTR's on there with the E load rating.
I believe my current wheels are the same specs, so no problems there. We'll see if I have the same wheels let alone the same truck by then. Anything is possible lol.
Damn i just got the bumper and sliders done.. that was about all my spending money. the rest is for the trips!
No worries at all. I just need to get these two things taken care of before i go.
