Crazydubman's 97 limited runner build
Well sorry for the lax picture updates.
Hopefully these will make up for that :surfer:
ResizedImage_1348538559832.jpg~original
2012-09-24_19-03-55_161.jpg~original
ResizedImage_1348538601100.jpg~original
ResizedImage_1348538582418.jpg~original
ResizedImage_1348538510108.jpg~original
2012-09-24_19-00-05_696.jpg~original
Bumpers painted and mounted - Check (need to fine tune the alignment on the front... May need to shim the crossmember from the bottom to tilt it back some)
winch and 100 ft synthetic line mounted - Check
Aluminum fairlead - Check
100W Hella Micro DE projector fogs - Check
CB antenna and Coax cable mounted - Check
Flag mount - Check
Still to do:
100W Hella 500's and light tabs
CB wired up and powered
Trans cooler
switches in dash for lighting
fuse block for all extra power needs
Sliders welded up
Rock lights mounted and wired
Whitson metalworks roof rack
install raingler cargo restraint netting
Storage racking for cargo area
There is probably more, but thats a good start hahaha. :fro:
haha thanks Drew.
Actually I forgot one other thing that I am following up on tomorrow... yet again...
3 high output LED pods per side drilled and mounted to the little panel under the headlights. (Like Dirtco's setup)
That way i can do away with the ugly factory turns ziptied to the bumper....... Sucks but have to stay legal right...
Thanks Rod,
Still have a bunch more things to cross off the list. Most of which I have sitting in the garage waiting for the time.....
haha thanks Drew.
The LED's arrived today so I should be able to get them mounted and wired up tonight. Stay tuned this evening for pictures.
I'm gonna see how the 3 on each side work out. I may end up adding a couple more per side to fill in the space more. It looks like there should be room for 5 total if I space them out correctly. I'm actually running amber ones not the clear. I have always been a fan of the contrast of the factory lens's on cars over clear and smoked. Call me a purest :tongue:
hey i dont blame you. thats why when i got my 99+ headlights i had to get 99+ marker lights to lol.
Very true. The headlights would be a nice addition some day. LED tails would come first though. Need to get my LED panels wired up in the 3rd brake light too.
I will be building a custom one actually off the factory one. 2 or 3 red LED panels mounted behind the factory red lens. Just need to silicone a plastic panel inside flat against the reflector and use self adhesive backing tape for the LED panels. I believe I can fit 3 but have 2 currently. Save yourself the 50 bucks and pick up a couple red panels like what you just got for the dome lights. they have a spade connector adapter included. solder the leads together into one harness and run them to the factory bulb socket. :D
We will see how it works out.
good luck with that haha, im not good with wires lol.
im trying to get the bmw all up and running and thats hard enough haha
REE
