smkd13
The poly bushing will deflect way easier than a steel bracket or link. The heim is a solid mount and there is no deflection. The shock load is what wallows out the holes not really the articulation. You have to remember the factory links have rubber on both ends and the mounts are perfectly fine. The heim on one end will more than make up for the articulation needed for a link.
Ok that makes a lot more sense to me now that it is explained that way. Thank you for correcting me on that and I forgot about the rotation of the hiem as well. I will probably follow that and skip the weld washers frame side.
