So since my sway bar end links were bent I started down this whole "well if I'm down there I might as well replace this..." mentality. I know if it aint broke dont fix it but most of what I wanted to accomplish was actual upgrades.
After getting under and finding my sway bars bent I took the sway bar off and while doing that saw my CVs were leaking on my drivers side. I was not surprised in the least as the truck is now 220K miles (110K of lifted driving) and these are original! I also noticed that since grease was everywhere my steering rack was all greased over and had a slight bit of give to it. As the bushings had never been replaced on it I marked that down on the list too.
List now sits at-
End Links
CV Joints
Steering Shaft Bushings
I had actually let the truck sit for about 3 weeks as we were on vacation and while gone, I got into this whole idea of a complete restoration on the front of my truck. Take everything off clean it, put new seals, joints, bushings, cvs, and replace every consumable and fluid. Luckily I have an M3 to drive in the meantime...
Lists now sits at-
Trans drain/fill
CV Joints
End Links
Steering Rack bushings
UBJ/ both sides
Upper Control arm Bushings
ARB Bumper cut and adjustment
All new clips and fasteners
new differential seals
Timing Belt
Waterpump
belts
Crank seal
Degrease
Here we go:
Suspension, axles, diff out, degreased and painted:
Front diff out and cleaned up!
Engine under surgery. To get to the Crank seal you have to remove the timing sprocket. As I was prying it out I easily broke a couple of the teeth off the sprocket. It is extremely soft metal and it actually looked like some of the teeth were already compromised. :
Pretty new Sway end links:
Love removing old rtv...
New trans Filter coming up:
