custom sub box for the rear storage compartment
Hey that's a really clean sub install. You still digging the bass out of it ? Have you made any adjustments or mods since the install ? I'm looking and scratching my head about making something similar. I have an older Sony Xplode box in my Runner and it just takes up to much precious space .
yeah it works great. I havent touched it sense i put it in. i think if i was gonna go back and do anything, i would try and make the box a little bit bigger and put a 8 incher in replacing the 6 but it doesnt bother me at all. if i want to feel it a little i can just turn it up.
if you have the time to do it, its great.
I think I will . So you constructed a box behind the panel , basically ? How did you attach the mdf box to the plastic panel ? I have a 10" to use .
i dont have any pics of it, but if you look at this pic, there is a shiny bolt to the bottom right of the box. There is a piece of angle Al that bots to that one point and also another on the pinch weld on top of the fender. i drilled and tapped the Al. If you take the sub out of the box, it bolts down to the piece of Al.
1230091218.jpg~original
this looks great. did you line the inside with anything? I bet if you put dynomat or fake-dynomat in there it would make a huge difference.
How much of a pain in the ass is it to remove that panel ? How did you fasten the box you made inside , to the plastic panel ?
my truck is all packed cuz im leaving for mammoth tomorrow but its just bolted down to the angle aluminum i put in.
ok i took the driver out for you so you can kind of see. Turns out i sealed everything is silicone and im going on a 5 hour drive tomorrow so the tunes will be cranked, didnt want to risk it not getting sealed properly again so i did not take the actual box out.
Anyway here are some of the pics. As you can see, in the bottom of the box there are a couple of bolts (covered in silicone) which bolt directly into the peice of angle aluminum i bolted to the body. hopefully these help.
IMAG0089.jpg~original
IMAG0090.jpg~original
I wish you had done a write-up! I am running a little bazooka tube right now to save space, and even that little think annoys me.
FWIW, this isn't mind, but I found this on one of the forums a few years ago. Same concept as you..
I'd definitely go the same route as you guys if I were to do that.
I like both of those and am going to do that . Just not sure how to attach the actual box behind the panel , to the panel itself so it has a legitimate long lasting seal. Thx for the extra pictures. I see you have fishing rods twitchee , good luck fishing .
I want to cry. That is the most beautiful thing I have ever seen. (Minus that JL W1V2. Terrible sub, other than the looks)
Fenrisx, I need you to remember where you found that picture! I need to make one of those...
when i get home at the end of the week ill pull my whole box out. the side panel is NOT the box. there is a .25^3ft box i built out of MDF behind the panel.
PS hopefully the rods will be in the water in a the next hour or so the view from the cabin im at is awesome. heres a teaser
IMAG0094.jpg~original
2nd.....I need to do something like that. It definitely has the factory look to it.
AlaskaRuss
