Cutting the front bumper for tire clearance
Fightman80 that runner is clean as hell! I love it! I just like that style bumper better for some reason. It just looks cleaner to me...
Thanks man! I was pondering getting the 99+ setup when I replaced my bumper a couple of years ago.... but decided to keep the 96 - 98 style instead. Glad I did. :)
Good luck with trimming yours... If I can suggest one thing.... trace out the line you want to cut with a sharpie or some other writing tool. Then heat up an exacto-blade with a propane torch, and just cut away the unwanted plastic, with the hot blade. Makes a much cleaner cut, and a whole lot easier than what I did... (used a jigsaw... lol). :)
Awesome man! Thanks for the advice! I never thought to heat up the blade.
this is what i had it looks pretty similar to your set up.
<a href="http://s1324.beta.photobucket.com/user/toykidd1/media/IMG_0138_zpsc38da1d9.jpg.html" target="_blank"><img src="http://i1324.photobucket.com/albums/u602/toykidd1/IMG_0138_zpsc38da1d9.jpg" border="0" alt=" photo IMG_0138_zpsc38da1d9.jpg"/></a>
i did something close to what you did but with alittle less removal and keeps a nice line i think.
PS I hate the Fat Lip bumpers
IMG_2577_zps0daad4d9.jpg~original
Now I'm wanting to clean up the lines on my bumper. Is there a certain blade used to cut the metal part of the bumper?
Grinder with cutoff wheel works great or if you wanna be extra carful then use a dremel with a cutoff wheel. Or well I suppose you could use air shears if you want. Just make sure you clean up the edges lol
Holy hell that would suck an take a tone of time!! I used a grinder with a cutoff wheel. Just melts the plastic and then a orbital sander to clean it up. You could also use a sanding block too.
Definitely use a sharpie though. Mark, check, adjust mark, check, have buddy check, adjust if needed, cut! If you f**k up they well there is no going back and you might be trimming more than you intended!!
AndiGarage
