CV Axle Replacement--Almost Done---Quick Question-->
Holley
Just finishing up the CV axle install on the passenger side. I have everything back together except the wheel. I tried to turn the hub just to make sure everything spins freely, and it doesn't....
I can spin it halfway and then it binds up. I can tug a little harder and pull it through the "bind". Does that sound right? Should it spin freely, even if the other front wheel is on the ground?
It's only binding at full droop. After searching around that seems to be common with aftermarket axles. :Cry:
This is a new Napa which supposedly has a better reputation, but it looks like this one is going back to the store. :smash:
Now this Napa axle won't come out of the diff:vader: It's putting up a good fight.
I have tried every pry bar and hammer combination i could think of
TerryNap61
