CV install question?
BobLMTDT4R
I replaced my CV for the 1st time last night and HOPE I installed it right. Followed direction from this site that I found....only one problem.
The directions to me to install the inner boot as far as it would go in..then smack it with a crow bar so the snap ring would make a pop noise and snap into place. Well after an hr of smacking, no pop. The CV goes in and is tight, and I had to use a pry bar to get it out. Is this normal, am I missing something? There is also about an 1/8" gap between the edge of the inner CV and where it connects to.
On the outer CV There is also a noticible gap between the dust collector and the knuckle.
I was only able to install 1 last night, so I have 1 new and 1 very old one. While driving home last night I noticed an uneasy vibration/floating feeling at about 65. This is a very concern to me since I don't know what it coudl be.
ANY HELP IS GREATLY APPRECIATED!!!
Bob
You won't always hear the snap ring pop...but if you had to use a pry bar to get the axle back out then it was in correctly...if it's not snapped in, it'll be able to be easily pulled out by hand
:iagree: Done a few in my day, these are no different. I've done 4 axles in this beast.
I just had mine out and back in. Neither one made a popping sound when they were all the way in. They both have about a 1/16" gap between the CV and the diff housing.
Bob
Bob, you should edit your e-mail address out of the post. bots will find it there and put you on spam lists.
Thanks for all your help. Today went way easier, 30 mins and done.
There is still one thing I am concerned about..on the pass side, the outer CV does not press up against the knuckle (what the spline slips thru). there is about a 1/16 gap there and the outer dust cover does not cover it. Is this an issue, should I try to take it apart again and see? I have it tightened as much as possible.
Thanks Again
Bob
p.s. nelsonmd...thanks I will
seltzernator
