Northern Bigdoggy
Hello all..... ok second post....
Bought a 2005 V8SE
now lets just say i bought it used and now have to make the best of it....
So.... testing out as many things as i can to make sure everything is working, i have come across this problem for now...
the DAC will not activate, nor will it even light up or even flash on the cluster panel. So upon reading as much as i could, lets just make sure i am understanding this right before asking for causes.
pressing the DAC on the middle console, should start the icon on the dash blinking i beleive? if so it does not....
I tried placing it in 4lo, down into lowest gear "L" and still no light......
Sooo,,,,,, i am figuring something is wrong......
What i could find for possible problems anywhere would be: possibly the switch is bad? i also read somewhere that it could be the master cylinder solenoid, but not being that mechanically inclined, would i not notice that else where in the braking system? anyone else have any ideas?
No other lights come on as indicator problems..... so not sure...
also the HAC wont activate either, which is if i presume right again, push the brake pedal down hard for a few seconds, i did as long as 10, and as long as it is in gear D in my case, i should see the skid indicator light come on and hear a buzz...... any help would be much appreciated.
Bought a 2005 V8SE
