Dades Bluegirl build
dade73
**** update - new suspension is installed ****
So at first I wasnt going to do this, but I wanted to just share some of my progress, struggles, and goals. I know many others have already done it, but maybe I could encourage others to not surrender to the fear.
Currents Parts List. This is Stage 1. Most of this is sitting in my bedroom. Stage2 and 3 purchases will start depending on overtime availability.
Large hardware:
C4 Low Pro winch bumper
Gobi Stealth rack 40" light bar set up (will be in this month) - Yes I was part of the Trail Duty orders incident
MobTown Offroad Rock sliders - kick out and full step plates ****now installed 1/25/19****
TRD skid plate
Wheels
TRD black matte rims
BFG KO2s 275/70/r17
Power stop rotors and pads Z36 rotors and dustless pads
Suspension:
Dobinson's
3" lift
Front...……………………………………………………………………………. Rear
springs C59-352 22-300lbs heavy load............………..C59-677v
shock GS59-574.............................................…...long travel
Metaltech brake line extentions
Portable daylight:
Auxbeam 40" 240w dual row 5d combo light straight
offbrand 3" 18w RGB LED Pods for chaser lights
NiLight 20" 100w slime LED light bar for bumper
power grid and install: Dades Bluegirl build
Recover
Winch- Smittybilt X2O 12000 Pro
recover boards - 2 - boar4x4
2 - X bull mind you both sets of the boards are exactly the same. I wanted to see what a $10 difference is
install info: Dades Bluegirl build
1st round base coat failed. Gotta Love the MD monsoons we had. Please keep in mind I am not a pro. No I don't have a booth to spray in.
After 1st attempt at base coats. Sanded down. cleaned. new spray gun. paint layed down much better I think. 3quarts of paint in total of about 15 coats.
OEM paint code 8S6 to match my truck
Base coats done. clear coats done. 1 quart of clear. yielded 7 coats of clear on the front. I did not clear coat the inside. Since it wont really be exposed to UV. but it did receive primer and base coat to help protect against rust.
Here it is in sunlight. I will be mounting the winch and light bar on it this week and hopefully installing on her. I was hoping the bedliner coating I did on the cross bar would be much deeper black. but as you can see, it has a grey haze about it.
You are not Powder Coating it? In that location you need toughest paint you can get. Save some paint for touch ups. Looking good, though.
I thought about it a lot. But everyone was doing black or white. My T4R is blue so I put almost a gallon of OEM paint on it
Smittybilt 12000# winch mounted.
Plastic bumper off. the center bar in front of the radiator needed a little trimming to fit the winch. also needed to move the power steering up a little as well.
BillM777
