Dash back light comes on when braking + rear hatch light flickering
thewaydown
My dash back light (NOT parking brake light) comes on every single time I brake. Anyone had any issues with this?
Also, just noticed today that the door ajar warning light flickers when I drive, and I found out it's coming from the rear hatch. If I open and close it, it turns off, but continues on flickering as I drive. I did just recently hammer the metal latch slightly towards the front of the vehicle (a recommendation i found on this, or some other toyota forum), as I was having some rattling from the hatch. Which solved the rattling issue mostly, but now the light is flickering, which means I can't lock my doors if I don't get out and open and shut the hatch.
Any ideas?
Not sure if a dying battery would cause this. I had flickering dash lights that seemed to happen as my brake was pressed happen as well.
I replaced a brake switch, battery, third brake bulb and removed my amp all around the same time so any could have been my gremlin.
Any ideas?
Did the dash back light start doing this when you hammered the latch or was it doing this before the hammering?
Does having the headlights on have any impact on the dash back light when you step on the brake?
That's worth a try. Some sort of tape maybe? I'll give that a shot and see what happens. Thanks
Yes I think something self-adhesive would do just as a quick 5 minute test. You could duct tape a penny or something, just to give it a bit of solidity and thickness.
seltzernator
