Dash LED MOD
Yes, you can the get LED's that you need for your HVAC display at superbrightleds.com store. Specifically, per emelianenkov:
"Neo 3 LEDs for the knobs, defrost, recirc, and mode/reset, and 2 Neo 4's for the LCD display"
Hope that helps!
i believe those 2 are the neo 4's could be wrong. i know the hole for the neo 3's need to be opened up a little, i don't recall having to do that for the main display there
From my experience, the Neo 4 doesn't work in the screen. It fits perfectly but doesn't light up. This has been true for others as well. I would just get a Neo 3 and put it in the plastic stock 4mm bulb holder. Neo 4 did work for me in the 4wd knob though.
neo 4's will work for the screen. i did get like 1 or 2 duds out of 4 from superbright leds but they def do work. i gotta order more now because that extra 1 was for my 4wd knob....also not looking forward to taking all the dash apart again just to get to the 4wd bulb :Cry:
Mike and I both got white duds... don't think it's coincidence?
[MENTION=88231]having fun[/MENTION], did you use white?
mine were white too. one actually worked for a bit then kept going in and out before finally crapping the bed
What happened to both of us was that the LED would light up for half a second when you plugged it in, then crap out. tested the contacts with a voltmeter and came to the conclusion that it wasn't supplying enough voltage to power the led/the resistor was too strong.
Wasn't me ZAK, but, emelianenkov does these mods for members on there dash assemblies.
EDIT: You could probably send him a message for info.
In my situation, the Neo 4 did not work in the screen but did work in the 4WD knob. The same exact bulb. When it didn't work in the screen I though "oh what the hell might as well try it" and it worked. I changed it back and forth and got the same result every time with 3 or 4 different bulbs.
I got a few Neo4's from Superbrightleds.com that I thought were duds. However, when took an Xacto blade and sort of pried/bent both contacts outward (widened the overall diameter of said LED) on each LED, they ALL worked like a charm. Not a single dud in either white or blue! Just something to consider.
I just need bulbs for the reset/mode screen...I just want to purchasethe right one before spending a bunch of money buying different bulbs trying to figure out which one works lol
Superbrightleds has been really good to me about dud LEDs in the past. Just contact them and they'll get ya replacements quick
tuṣṭāva
