Daystar Coil Top Spacer on OME 881?
Kanger328
I have OME 881 coils set up with Rough Country N2.0 struts up front. This only gave me about 1" of lift, so my front sits over 2" lower than my rear (OME 890). Will I be able to use Daystar's 1.25" coil top spacer for the front? Here's the link:
Daystar 1.25" Lift Front Coil Top Spacer Kit
I tried emailing Wheeler's a couple times, but no response for some reason...
I'll chime in since I'm running something similar, I've got RC tacoma struts, 881's w/Toytec 1/2" top plates w/extended stud kit and also stacked a Wheeler's 1/4" Poly top spacer to give me a lift of 3" up front (38 1/8" from ground to fender) -So my top plates combined is 3/4" total in front.
In my opinion I think you shouldn't go beyond a 1" top plate in combination with the 881's, that will put you beyond a 3" lift up front.
BTW The Rear sits at 3.5" of lift (39" from ground to fender) with Superflex coils, so my 4R's stance looks even.
This set-up has been good to me, I've had no alignment issues, my front end handling is good on and offroad.
Hope this helps. :tea:
Thanks for the info! Hmm...sounds like this option is going to cost me a good amount. Maybe I'll buy the Toytec/Eibach 3" lift springs and sell my OME 881s.
I only got 1.2" of lift with the OME881. I was hoping I could add the Daystar 1.25" spacer to get just under 3" of lift up front.
Anyone else?
DexterShaYang
