Daystar comfort Lift installation question
Hey man, your 4runner looks awesome. I am planning to install the daystar lift and 275/60/20 nitto's on my 4runner soon. Do you have any rubbing? Did you need to do the fender mod? Thanks!
I have the same lift on my '12 LE, although I'm running Cooper Discoverer AT3's. I had a ton of rubbing, not even close to full lock. Ended up doing the fender mod, which was easier than I anticipated. No cutting but had to move more on the passenger side than the drivers. Also required moving a small plastic piece to actually get at some of the hardware. Would be happy to answer any questions if you have them.
Quick question regarding the Daystar kits, is there a difference between their KT09124BK ('07-'14 FJ) and KT09134BK ('10-'13 4R) kits? Some threads here use them interchangeably, and others have even used the 4th Gen kit (KT09115BK) .... curious what the differences are, can't tell from google searches.
Reason I ask and not just order the 4Runner kit is I can get the FJ kit a little cheaper, but not enough to matter if there is a difference.
EDIT: Will be going on my 2015, assuming nothing changed suspension wise and Daystar hasn't updated listings?
What did you have to do with the hydraulic lines to get the lift installed. My installer isn't sure how to not mess up the lines.
I have had the day star KT09134BK kit on my 2011 limited for over a year and I have been very dissatisfied with it. I am running 275/60/20 Terra's and the ride is awful. I have gotten 4 alignments and it still pulls. Highway driving is unstable and tends to wander. Spend the extra money and do it right the first time.
I just ordered the toy tech ultimate 3" lift today and going to install it in a few weeks
Really a total mixed bag of reviews on the daystar 2.5/1.5 level kit. I personally just installed it on my 2014 Limited and the ride is perfect. I felt zero change over stock and haven't even done an alignment yet. Waiting for my new wheels first.
Very satisfied with this wussy lift for $150 bucks....
Very satisfied with this wussy for $150 bucks....
I installed mine last weekend and it's great. That plus the BFG KO2 275/70/17 riding on SCS Stealth 6 wheels are great. Lost about .5 mpg and rides a LITTLE rougher but that's mostly the E tires.
Leave the XREAS lines connected to the shock but unbolt the bracket that holds the line to the frame for a little more play.
