Dead rodent smell inside 4runner
TRDfan2011
Member
Last night left work and a bad smell of dead rodent hit me when I opened the driver's door. While sitting in truck it seems to come from everywhere but it appears to be strongest in the cargo area. I got under the truck and didn't smell anything. I thought maybe something died in spare tire. Looked around engine bay and no smell either. Anyone knows if there is any opening that a rodent can enter into the truck? Won't be able to take cargo area apart till I get back from vacation. Also looked under seats and no smell in that area. My truck is going to smell ripe by the time I get back.
Well a mouse needs a hole the size of your pinkie to get into the car and a rat needs a hole the size of your thumb. Probably a bad idea you went on vacation without finding it. You may have a permanent smell in your 4runner.
Can't do much since I'm leaving Friday morning and still
have to take care of a few things. Gonna look for entry points.
Thanks for info.
time to drop the headliner I'm afraid.
Having done enough rodent infestations and totaled two cars so far this year. I can tell you that the headliner is the last place they get into, usually because they've been everywhere else. If they're in the headliner, it's probably totaled at that point because they've been in everything else except the door panels (they don't seem to really bother getting in the doors for some reason, I guess it's mainly because they'd have to eat through the speakers to get inside them vs. everything else?)
If it smells like a dead rodent, you probably have an infestation in the vehicle (usually you won't notice it unless your sensitive to smells like me until it gets sizable. First spots I would check are:
-Cabin Air Filter
-Spare Tire Tool Area
-Back Panels where you can remove covers.
IF you do find stuff on the cabin air filter or in the back, do not clean it out without taking good pictures to show your insurance.
Usually what happens is they get in through the cabin filter area, eat through that, fall into the blower motor... if they don't get blended up by the blower motor, they make their way into the HVAC unit and/or into the car from there. Usually they will find spaces under the carpets, behind quarter panels and start tearing up the insulation matting to make nests.
At this point, your best bet would probably be to take it to a shop or dealer and have them start by checking the usual spots, maybe pull a panel or two and determine if further tear-down is needed.
Some vehicles I've done have been as simple as cleaning out the blower box, installing a new cabin air filter, and a rodent screen. Others have required replacement of the entire HVAC assembly (about $4~5k in parts and 8~12hrs of labor). Most recently I've had the insurance total a 2013 Sienna and a 2012 Prius because it needed the entire interior, HVAC assembly, ect.
Not trying to scare you, but I see a lot of rodent issues in my area since I moved up here and am just being honest about to look for/expect.
This was my cabin filter the other night. I don't think it was new or from my area.....I think it was from a one night stand(the mouse) in Colorado this past summer, no poop or evidence of babies, but I did find bright green moss in the nest, we don't have that in abundance here. That's why I'm hoping it was a one night thing, but that lil guy must have had one good party!
[MENTION=139892]FrenchToasty[/MENTION]
I got ya beat... Customer stated they thought they smelled something and the blower wasn't working well.
I found where all the missing bird seed in their garage went... all about 5 pounds of it. Thing was filled to the top.
Took 3 more dumps after this picture to finally clean it out.
Rodents really suck. We just had a lady with a 17 rav4 get some harnesses chewed up. Insurance paid out over 6K then she came back 4 days after picking up the car same thing happened. In our car lot alone we had 3 cars with rodent damage the last 2 weeks.
Thanks for info.
Strongly suggest you leave some spring traps baited with peanut butter. 2 in the engine compartment, 1 in each front footwell, 2 in the way-back. The ones in the car should be sitting on a piece on newspaper.
Do this regardless if you find one before you leave.
Do not leave poison baits. They just eat it and crawl inside some place to die. Glue traps second-best to spring traps.
OP, change the cabin filter. Sometimes I run without one for a few hours just to make sure everything is clean and dry as wind velocities will be higher without the filter.
As far as rodent screens? Those are just petty challenges to mice and rats. They have a map of your vehicle and like any good first person shooter game will explore all options if they want in.
Thank you all for your advice/suggestions. I did a quick over on some suggestions. My k&n cabin filter only had a few leaves. Didn't see any dents/holes on filter. Blower motor area looks brand new. Rear jack compartment did not show anything unusual. Used flashlight as I checked interior. Under the hood did not show signs of any wire tampering (did notice a stand-alone round plug near the eng filter box with nothing connected. Could be an option that wasn't added). I diluted some Pine Sol and sprayed the wiper cowl as well as the carpet, under seats and cargo. Apparently Pine Sol is an irritant. Gonna try to pickup traps and place them as suggested. Again, thank you all for the replies. I'll update after returning from vacation and spending quality painful time with my truck. I may take apart the cowl area first to see if something just died in there and permeating my truck.
Are you sure it is inside the vehicle?
I had the city set up poison rodent bait in my yard and one of them decided it wanted to die under my hood in the fender area.
Took a while to find it, because it smelled like it was inside.
I had what I thought was one field mouse living in my Blazer for awhile. I finally put a snap trap in the passenger floor well and caught two with the same trap. Its hard to imagine they were trapped but two in the trap makes me think they were starving. Oddly no damage to the car that I've ever discovered.
Dead things smell really bad. Even small ones. If you just think its a dead thing it might not be, or its somewhere the smell is being contained.
Of course the good news is eventually the dead smell usually goes away after a long time.
freddygino
