Dealer service prices
bokmeipai
I just dropped off my T4R for the accelerator pedal recall and asked what it would cost to change the differential fluid. I was quoted $189 EACH for front and rear ! Are the nuts? almost $400 to change front & rear differential fluid, their defense was that they don't just drain the fluid they use a machine to flush it. Obviously I turned them down. Has anyone had their diffentials changed at a Toyota Dealership and what did they charge you?
I had F&R diffs, transfer case, transmission fluid/filter, engine oil/filter and cabin filter changed recently at my indy. They also lubed the prop-shaft etc, did a complete inspection, checked out my TPMS problem and changed the serpentine belt. I provided all the fluids/parts and was charged $106 for labor.
The dealer cost for the differential fluid change is mostly for the oil i think.
I had mine done a week or so ago and it was VERY pricey, mostly due to the oil thats used in the diff's and the transfer case. I remember that the oils were 2 different kinds, as the 2 diff's are different and require different lube's.
I asked about a tranny flush and fill, but they said its a sealed-unit and good for 100k. I said, "my '03 gets it done every 30k! Are they different trannys?"
So i pose that question to you guys. Have I been getting hosed? Is the 08 tranny different from the 03? Is one changeable and the other not necessary due to a design change?
Help me out!
Help me out!
Haven't looked into it on my 4R yet, but on both of my Volvos, they say the same thing. The dealer basically won't do a tranny flush as there is no need. I think a lot of vehicles are like that now, but it sure seems odd to me.
I run redline synthetic 75w90 in both diffs and the transfer case. Dealer charged me ~$110 to change diff fluids and xfer case fluids as well as an oil change with me providing all fluids.
wow my dealer must a real 'Stealership". People that don't know anything about cars really get ripped off by them.
Well my dealership was a stealership as well. But i talked to Toyota about replacing my rear door handle and how the stealership is runining their fine vehicles. Then the stealership turned into a dealership. Lets see how long that lasts.
I was quoted $99.99 for both diffs and t-case about 3 months ago... Which has me really thinking whether I should have them do it, or do it myself using synthetic for about the same cost.
So then how much is a decent price range for a V8 tranny flush n fill w/ new filter?
People have been quoted around $200 for it in the US but others have been hosed for much more. Of course in Canada you are required to leave your first born child as a deposit.
How did you start talking about tranny flushes from Differential flushes?
If you're talking just differentials (axles) then you're getting ripped off. It's just like changing oil with a drain and a fill plug. Do it in your driveway.
For transfer case (center diff?) and transmission they do have machines that will flush a lot more out than you can get so that may be worth it.
