I took my 2008 4Runner Limited 6 cyl, 58,000 miles, in only for the yearly PA state inspection. The service rep said that though the brakes front brakes showed a little more than "4" and would pass inspection, he'd recommend new pads, resurface the rotors (new rotors were installed at 35,000 with pads) for $346 plus tax. Also, brake fluid flush at $129.95 plus tax, a tune up with new iridium plugs at $165.95 plus tax and 4WD diff service at $175.95 plus tax for a grand total of $817.85 plus tax. I suspect the propeller shaft lube is included or maybe he didn't want to push the estimate over a GRAND!
This all seems very excessive to me. I can replace plugs and simple maintenance stuff. I do some work on my '71 MGB. Is there anything complicated about this stuff on the 4Runner? Also, as far as grease, can I use just a good synthetic grease for everything needing greased? The maintenance schedule mentions two different types of grease.
Thanks,
Gene
Thanks,
Gene
