TPMS Replacement Cost
scw1991
My 07' just turned 113,000 miles on the odometer. The TPMS indicator lamp has blinked a few times in the past 6 months for short periods of time. Now the indicator lamp blinked continuously.
Purchased the vehicle in 2011 with 50,000 on the odometer and don't have any vehicle history. The brake pads and OEM sized Michelin tires appeared to be new from my initial visual inspection after purchase. Pleasantly surprised to obtain this much mileage/lifespan on the same set of tires, pads and TPMS sensors.
Did quite a bit of research on disabling the TPMS. Looks like there are few ways to bypass the indicator lamp and folks have had success. Per review of a Toyota TPMS electrical schematic, I was a bit leery to take this route due to the nature of solid state electronics and their complexities with system voltages & impedances. Plus, the indicator lamp is there for a reason. I, like many others check tire pressure often but there are times where time passes a bit too quickly and it is overlooked....especially during the frigid winter months. But, I'm always concerned about the wife when she drives the vehicle. She may not be able to sense a tire that's low on air pressure or slowly going flat while cruising down the freeway. Couldn't live with myself if she were in an accident due to my negligence.
Opted to simply replace all (5) TPMS sensors today at Costco. Grand total including tax was $312 ($45 per sensor + $14 to install for each wheel). I've purchased at least six sets of tires from Costco throughout the years and have had superior service. They seem to take their time to do the job right. Plus I like the fact they don't get overzealous with the impact gun. I watched them wire brush the mounting surface of each wheel and rotor in addition to wire brushing the wheel studs. They also use conventional torque wrenches and two separate individuals check the torque of each wheel. Nice checks and balance system.
Steve
Thanks for the info. That (I assume) includes any programming?
So they will install even if they aren't the installer of the tires? Any idea if they would be willing to install sensors if you brought them in yourself?
Yes, programming was included. Should have included that above.
Not sure if Costco would install sensors if purchased elsewhere.
My aunt has been noticing the tpms indicator lately and asked me to check it out. Her '08 is at 110k miles now so I guess it is time for a new set of tpms. I'll just finish installing the shocks and skid plates from 4Wheelonline onto the Wrangler this week before I take a closer look.
i bought a sensor around $25 each. the issue that you might have is removing the old one due to corrosion.
Steve
Steve
Discount Tire, or Tire Discounters did mine for $75 a piece with programming for mine.. Either that or they forgot to charge me, but yea around $300 seems reasonable for a safety feature that might save your life at 75mph in a topheavy rig.
Update:
Had a set of Michelin tires put on our other car at Costco a few days ago along with new TPMS sensors as well since the car is 9 years old with original sensors. No additional charge other than paying for $43 sensor itself when installing new tires.
I asked tech if they’d install customer furnished sensors. Tech said no. I get it from a warranty standpoint.
Could be this particular location only. But, thought I’d share.
I wouldn't mind $300 to replace and program all of the sensors, not even $500. My son's dealership in Minneapolis and mine here in central Kentucky both quoted $400.... per tire. Now that is outrageous. The Denso sensor on Amazon is about $35. I checked with Tire Discounters and a local repair shop I use. TD wanted $300 per tire and the local shop said they don't have the software Toyota requires.
I have learned that the blinking is usually from one sensor. If any of the other tires' pressure drops then the blinking will stop. Just let out air to about 20-25 PSI and if the blinking stops then that sensor is good, if not, that's the bad sensor.
There are some YouTube videos on doing your own but I'm not taking a chance on destroying my new tires. What I am considering is paying a shop to break down the tire and install my sensor, then air it up again and balance. I can get the cable and software from Amazon I think. If that doesn't work then I'll just live with the blinking.
erinobr2000
