Desperate: 1989 Master Wondow Controls
Smitty777
Desperately looking for the master window switch for the drivers side door. Cant find this thing anywhere?
Anyone???
Do the ones off a early second gen work? I know some of the stuff from the 89 carried over
Are you looking for the rounded arm rest from the 1st gen sr5 or the standard switch. The 1st gen had 2 different power window switch styles
I dont know what I need other than the switch. The worst part is I cant find the original so i dont know what it looks like to match it up.
I have the 89 SR5 and i dont know if other years work.
did you test the switch.
if you have power windows and its a 1st gen 4runner, the little black box is usually the problem
Sounds like he never had a switch. I'm guessing he picked up the rig missing the switch and is just trying to find one
Thanks guys...
I originally had it but tore the interior out. When outting back together the switch kept blowing fuses so the mechanic said needed a new one. I have not been able to find it since then. I have order 3 so far and none of them are the correct ones so i returned.
More likely its a pinched wire. Had the same issue with my radio fuse and closing my door. Why my electronic mirror controller is connected to my radio fuse I will never know
so which one is it
this is the 1st gen late model sr5
image_zpskq1ooiig.jpg~original
this is from a Dexlue 1st gen
image_zpsgg4agebg.jpg~original
2007T4RunnerSport
