did i pay too much?
reed1285
so I took my runner to a 4x4 specialty shop in Rock Springs, GA called Spicer's Off Road, to have a few issues fixed with it that I just couldnt find time to fix myself or I wouldve. It had a very...very bad vibration in it from 5mph on up. It got so bad that I didnt even wanna drive it cause it would beat you to death, so I was just driving my F150 all the time. I dropped it off last Friday and they actually got to it and gave me a call with the diagnosis that evening. Turns out at that point I needed both driveshaft u-joints, a new yoke, and a couple seals on the transfer case. All of which was gonna cost me $482 with parts and labor. I told them to go ahead and fix it cause I was ok with that. Well yesterday morning I get a call from him telling me Im gonna need a new driveshaft as well. He said they were replacing the U joints and noticed how bad of shape the driveshaft was in. He said I could get by with it, but if I wanted to completely erase any posibility of vibration that he recommended to replace it cause to him it looked like the old driveshaft couldve been a culprit in my vibration issues as well. He said they would replace it with a "heavy duty" driveshaft (rear driveshaft btw) that also needed to be a touch longer than the other one (stock) due to the lift. so now with all the previous parts and labor I listed above, + a new "heavy duty" custom length driveshaft, im sitting at about 900 bucks. Does this sound about right to you guys? Its been a lonngggg time since Ive taken one of my vehicles to a shop to get worked on, but I just couldnt find time to crawl underneath it this time and fix it myself, due to work and traveling. Spicer's has a good reputation around here, and are a 4x4 specialty shop, so thats why I chose them to work on it. Plus the guy Im guessing is the manager there is really nice and helpful. But at the same time Ive never bought a new driveshaft and was curious as to if it sounds like Im being treated fairly. Thanks for reading
Sounds about right. Custom lengh DS usually run 350 to 500.
How much lift do you have? Is it warped? Has it been bounced off any rocks? Driveshafts don't really "go bad" w/ out sone help from something hitting it.
Im fixing to go pick it up. I got the call that they were done with it just a few hours after i posted this yesterday. Total damage is $886. Im cool with it cause i had forgot they also fixed the problem i was having with it not going into 4lo. Im not sure on why they said i needed a new driveshaft. Im gonna find out when i go pick it up tho. He told me over the phone. the guy is kind of a mumbler so i couldnt really understand him. Nonetheless ill be glad to finally be able to drive it without being shaken off the road. So bottom line is custom length ds, new u-joints, new yoke, new transfer case seals and work on the transfer case linkage = $886. Which looking at it now seems about right
A warped drive shaft will cause you all kinds of problems.
Be glad it isn't a Cadillac! Everytime my 98 Eldorado goes into the shop it's usually a $1,000.00 fix.
If your's runs nice and smooth you'll know the drive line is now in good shape!
:lookout:
Considering shop rates are around $100/hr, doesn't seem outrageous.
A good custom driveshaft is easy $300+, I spent over $500 for a custom HD shaft from High Angle Driveline, long slip and double-cardan joint required for the steep angle.
my runner is driving 100% better now. The guys at spicers did an excellent job. It goes down the road sooo much smoother now. I paid 499 for my custom driveshaft. They kept all the jacked uP parts they took off to show me what was fixed. When he said the yoke was in rough shape he wasnt lyin. It was really bad to the point of being dangerous.
TerryNap61
