Differential fluid change
toybox
I just changed the gear oil in my differentials this weeked. The drain bolt has a magnet in the middle and I was surprised to see so much 'gunk' stuck to it. Now I really am glad I changed it because at one point I was questioning whether it was worth it.
I used 75w-90 Amsoil gear oil and used two new crush washers and it was pretty easy (expected).
BTW gear oil F'N STINKS to holy hell :( . I felt like taking a shower when I was done.
Lastly I still have to do the transfer case next weekend.
All gear oil smells really bad. My wife can smell it even after I scrub my hands with gasoline and then soap. I plan on changing them once a year. I flipped my crush washers over and reused them. I will replace them next time.
I think I will change out the differential fluid this upcoming oil change. How much fluid did they hold each? Please post up if you remember
msanta said:
Someone mentioned earlier touch up paint. What's the purpose of it?
A little nick or small scratch can be touched up with this paint. It is from Toyota and is in a like 1 ounce bottle with a small brush in the lid.
Please post up transfer case oil capacity when you change out the oil please! How many miles should the transfer case oil be changed at? Im thinking about doing it when I change out the diffs fluid. I currently have 24k should I be concerned about changing the transfer case oil?
thanks!
Re: Re: Differential fluid change
thanks!
I'm probably changing it out early but I don't know what the schedule prescribes. I wanted the break-in to happen and then change to synthetic and forget about it for a long time.
I have 20,500 on my '03 right now. And like Koz said, it takes about 1.5 quarts. BTW Boaz all the capacities are in your owner's manual along with the proper oil to be used.
Koz said:
Lets see, change the oil once a year or every 100K miles, and have better protection. Hmm! :bonk:
Koz
This discussion where be much more interesting if we accompanied it with a few pints of BEER. :p
Re: Re: Re: Differential fluid change
YEah I know im too lazy to look...;):
thanks!
toybox said:
Yeah, what he said.
Also I got a pump from Amsoil that fits on the top of the quart containers and it made it very easy to refill. Also I bought two new crush washers for the drain plugs but not the fill plugs. They were very cheap from partznet. I got both washers and a thing of touch up paint for about $6. One thing that was mentioned before in one of these threads....make sure you loosen the fill plug before you undo the drain plug. I had a little trouble loosening the fill plug on the front.
I have everything to change my diff fluid except this pump. WIll I be able to do it without the pump? I will have the truck up on a car lift so I hope I will be able to pour it in via a funnel. I may have to seach the local parts stores for one of those funnels with tube on it.
Whats your thoughts? Will I NEED the pump or is it just something to make the job easier.
Crookedcat
