Disabling TCS and Stability Control
Ohcrymore
So I discovered how to turn off traction control and stability control on my '03. I don't know if it works for '06 and newer as it relies on the truck using ISO protocol for its OBD port.
The TSB for the VSC, etc lights turning on includes programming the deceleration sensor. In the beginning of that process is the process to erase the previous "zero point" values. If you stop after erasing those values, your stability control and traction controI will be deactivated, leaving your ABS intact.
Enjoy!
I am just now seeing this and was wondering for clarification would pretty much any OBDII scanner be able to do this? Is looking like a better option than the other mods out there
is this a permanent deactivation of them? id love to be able to do this on my GX, but i want it selectable for when o go off road say like in sand or snow or in lose rock when climbing...
You don't use an OBD scanner, just 2 wires that you stick into the specific holes in the OBD plug and tap together when required by the TSB. This will leave the VSC and TC off until such a time as you complete the whole TSB and reprogram the deceleration sensor. Both wiping the values and reprogramming takes all of 30 seconds. When I can I'll make a video for you
I am thoroughly looking forward to this video, because like wadle5 said this looks like the best option for disabling this feature.
Follow these steps up to step 4. Use 2 wires with the ends stripped, tap them together to short and apart to open the circuit. To undo it, follow the rest of the steps.
Sorry for the delay on the video, it's a busy couple of weeks.
Good News!
Here's the video. First up is a picture of the OBD port (dust cover moved to the side) and the ports where the wires need to go.
And here's the video (from Youtube):
<iframe width="560" height="315" src="https://www.youtube.com/embed/TFsNSfXL5lM" frameborder="0" allowfullscreen></iframe>
And if it doesn't work, here's the link: https://youtu.be/TFsNSfXL5lM
To be clear, this does NOT affect your ABS.
Enjoy!
That is awesome. I just ordered an obd2 plug and a momentary toggle switch to make a more accessible option. Ill try it once i receive them.
Good job.. been looking for this forever and thought the tacoma or fj guys woulda gotta it first.
You don't need any special tools for this. Just a couple of lengths (equal length) of wire. Cut the wire to around 2-3 feet in length and strip both ends leaving about 1-2" of wire exposed. Insert one end of each wire into each of the ports, and use the other end as your "switch" (to tap together). Cheap 'n easy.
If i make this adapter i can do it faster and never have to worry if i got the right pins. Ordered the parts from amazon for $6
Best solution I've seen for this! The video definitely makes it easier to understand; might give it a try :thumb:
Step 9 has you apply a short. Is there a step 13 to remove the short properly to restore VSC? I want to be able to turn it back on. Looks like a great tip with no wire hacking. Ready to try it once the wheels are Plasti Dipped.
Take a look at the video, it explains how to reactivate VSC and Traction Control.
Is there a way to wire in a switch to make this do the same as the wires do?
You likely could but tbh it'd me more trouble than its worth. You could still have to cycle the switch 8 times to erase the point values. It's much easier to just keep 2 coiled up wires in your glove box.
Fair enough...I'd love to have this ability on my 05 functioning with the 07-09 button...I have it in my dash but have yet to make it work properly...
Thanks for the suggestion.
