DIY - Creating and Installing 4th Gen Wheel Well Splash Shields
Old thread, I know, but I'll be doing this and adding my body lift height to the trace-out dimensions. I saw the thread on TW for the full-coverage one and will be giving that a shot!
Link to the thread on TW for the extra coverage ones?
Save the time, great manufacturer in Colorado...Yota Liners
Yota Liners over at www.yotaliners.com is the answer to this. Homemade seals never last, just like the ones from the dealer. I have bought from them for my 4Runner and previously my Tundra and wife's Tacoma. They are a family parts business here in Colorado where I live, make them out of a patented neoprene-like space-age material resistant to everything, and include instructions and the clips which are really expensive and hard to track down the right ones even from the dealer. Their customer service is great. Ordered the wrong set for the Tacoma once, and they quickly swapped them out. Would highly recommend if you want to save yourself the time and re-work in probably less than a year. Just my 2 cents.
I just did this too, one was flapping in the wind.
Used some clear plastic to make the template.
1/16" water barrier membrane for tile shower floor...leftover from a shower repair. Its like inner-tube material. Super tough stuff.
Though I would try the extra coverage version floating around over on TW.
How are these holding up? I was looking for something thicker than 1/16 but maybe its not necessary. Also, did the tacomaworld template fit exactly, or did you modify it? Thanks
So when I bought my used 05’ 4runner the previous owner had torn these out probably when he did the lift and cuts for the 33” tires that are on there.. so I’m curious how important is it to get these back on? I’m up in the NY salt belt and I’ve got a fluid film coating done already.
Dealership tore mine off sometime in the past, probably when I was there for the 90K timing belt replacement. This past summer I bought new ones and installed them. I think they reduce noise as well as protect the engine from getting splashed with water and causing it to stall. It was an easy replacement, maybe 5 minutes per tire after the tire was removed. I got mine off Amazon.
Amazon.com: Set of Four Splash Shields with Clips for 2003-2009 4Runner (Fender Liners, Aprons, Shields, Splash Guards, Skirts, Guards, Seals, Splash Seals) C : Automotive
thadjay
