DIY Painting 4runner Parts
Jordanbiird
What do you guys paint on your 4runners?
1. Do you guys have a professional paint some of the parts on your 4runner?
2. Do you guys ever paint certain or all the peices needed to be painted on your 4runner?
3. What do you guys do to Prep the surface before you paint it?
4. Are spray paint cans good enough, or would it be smart to get a paint gun?
5. How many coats of primer, base coat, clear coat do you guys do?
6. How do you get perfectly matched paint, like Black, and is it cheap?
7. Is it safe to paint calipers or exaust pipes, or other items that can get hot?
8. Can you paint the interior of your 4runner, or is it just a sloppy mess that would be dumb to preform?
9. Also, if you guys do paint certain parts of your 4runner's, What paint do you recomend using for each peice?
Thanks so much, Give as much detail in your comments as you can, and even use pictures or links! Thanks sooooo much guys!!
I've done it all myself.
Front bumper and rear bumper, wheels, brake calipers.
Prep. Prep. Prep. Smithing and cleaning the surface as best as possible, scuffing it up etc so the paint adheres.
I've done my paint via spray cans, but if you're gonna do a lot... Buy a spray gun.
Most people have different opinions, also depends on the products you use. I would use the manufacturers recomended amounts.
Paint matching at a local shoppe or autoparts store, or toyota.
Prices depend on the paint..
Yes I've painted my calipers and they are holding up well. Use paint designed to withstand high temperatures.
There's products made by POR-15 to stain leather into a new color, it's a very time consuming process. It's all plastic inside so proper prep would be required. I'd recommend pulling the interior if you're gonna do it...
I use rustoleum and VHT haha. Pretty much all I use. I'd find a good plastic paint.
Sorry for no pictures or links. Using my phone is not all that easy.
Thanks so much, it helps alot to know this information!
x2 on searching here
There's also google. Painting isn't 4Runner specific, so there's no need to limit your searching to a 4Runner forum.
I was making a joke earlier, but seriously every question you asked has a thread topic about it in this forum. Including such things as "painting over stains in your carpet", Yes! http://www.toyota-4runner.org/4th-gen-t4rs/179495-painting-stained-carpet.html
Pick the specific thing you really want to know about at any time you need to know it and do a search, nearly 100% guaranteed to find a writeup about it already done :)
Yea, I think I found out how to search the forums, it helps alot, thanks guys !!
allcarhistory
