DIY: Painting those Center Caps
Drew
(No pictures just yet.... no camera... sry fellas)
I'm enjoying my Sunday by repainting my old beat up center caps.
I am just finishing my 1st coat and I gotta say that I am very happy with the results so far.
Those of you who would like a no brainer step by step then here you go.
Buyers Guide from Home Depot:
1. Rust-Oleum "Specialty Plastic Primer" (White) $4.87
2. Rust-Oleum "Indoor/Outdoor Durability" (Metallic) $5.57
3. Rustoleum "American Accents" (Gloss Black) $1.99
4. Norton MultiSand Sanding Sponge (Fine/Medium Grit) $2.19
5. Small Paintbrush Assortment $3.97
Grand total: >$20.00
Prep
1. Take those bad boys off.
-Give a tug and feel your shoulders and back crack
2. Sand those bad boys down.
-The medium grain is forgiving enough that you can be somewhat agressive. Get all of the hard to reach places and use your fingers to feel the plastic. It should be smooth with no pits, rough edges or flaws. (think smooth baby....)
3. Wash them with warm soap and water and let dry.
Paint
4. PRIMER- Get your primer ready and shake that bad boy like it's your money maker and you got bills to pay.
5. I always do a test spray everytime I start, and again if I stop for any reason before I reappply. I want to make sure that there isn't any blockage or sputtering. The key here for the primer is a light coat that is even.
6. Dry for 20 minutes.
7. PAINT- Same shake process as the primer, but the application is a tad different. Now I'm not a professional but a buddy of mine always said that the more coats the better. Now that doesn't mean that you should do 50 coats, but what he is trying to say is that if you just lay on one HUGE coat it will cover, but it won't work as well as a good 3-4 light coats one on top of each other. That makes an even, well covered finish.
8. I did 2 coats, you can do 3. I just got lazy. I'm wondering about a clear coat, I remember reading someone else doing the same thing and adding a clear coat, sounds like a good idea.
Conclusion
It really was easy and took about an hour and a half. In retrospect I would do the same thing again, and would advise you to do the same. Unless you want to shell out $60 for new caps. Plus doing it yourself really gives you a sense of pride in your ride.
Good Times,
Drew
It's funny how many 4Runners you see on the road once you own one.
I did mine. But I didn't even sand it all down, got really lazy, there were some spots with sand still there.
I had some problems with the paint being uneven and having pimples every once in a while, and on the spokes the running paint built up there for a bit. Mine don't look bad, but they don't look great also.
I think I know where those pimples come from, again I'm no expert but Im thinking.... yea. I have some poor quality coverage on the sides that run parallel with your lugnuts, that inner curved part of the cap. I'm thinking that I didn't sand that part down very well, compared to the rest of the cap, and hell I didn't cover it with a nice coat of primer either. Lol no wonder I have a rather unsatisfactory finish on that part. Other than that my results are really quite good, and I am very proud and quite surprised.
I'll post some pics as soon as I get a camera.
Sand, wash, primer and paint baby.
Drew
I didn't even use primer.
If I had to rate mine, on a scale from 1-10
10 being the closest to factory painting.
I would give it a 5 lol. I'm also not the greatest artist or anything so whatever, you barely can notice it when your not up close.
i swear i found somewhere online to get new caps for like 20 bucks. Also, i painted mine with some metal charcoal black paint, went on real even, and accents the wheels well.
I painted mine on my '97 and are getting ready to paint my caps on my '99.
I will paint mine the metallic silver (4 coats) then I will fill in the "T" with acrylic paint (red in this case) and then do 5 coats of clear and then let dry for a couple of days.
Just got thru repainting mine... just thought id share the results, ill have to get a pic of the after tomorrow but heres the before.... i went with white (toyota emblem) this time....
Kregg, next time you get your runner into a shop, you should think about getting those wheels balanced with adhesive-backed weights. You already have decent looking wheels, in that they dont have much corrosion on them. I just have always thought that even the best-looking wheels look like crap when there's some nasty wheel weights on the outside of the rim. The little adhesive weights will be virtually invisible, because they're on the inside of the rim.
I just wish my wheels looked better, even yours would be a treat in comparison. Cant wait to see the after pics.
yeah ive thought about it maybe when i get new tires, i have also noticed where wheel weights had been on the rim before, and they have destroyed the finish!!!:cursin:
and from a lil ways back... i really like the white better than red...
Nice job Kregg, they look good. On my first try painting the caps, the silver paint ended up looking a little blue, so I had to redo them. I've painted the Toyota emblem black pearl to match all of my other emblems on my truck. It's nice to have it custom.
thanks for the props my dad had a neat idea to paint the caps the same color as the body cladding and then do the white emblem - but i didnt try it , what would you guys do --try it or leave it??
Go ahead and try it. But how did you paint the white emblem on? I tried to cover my emblem with tape so my spray didn't get on it, but the tape wasn't small enough to fit in the emblem and its not really that great.
I might do a repaint soon.
tape over the entire wheel and put an exacto knife to it.
David
Just repainted my 4Runner Center Caps today
Just followed all of your suggestions and very happy with the results. Picked up a can of Rustoleum Pro High Performance Enamel, a perfectly matching metal silver to match my big rims. Color i used is : Aluminum 7515, cost me about $7.00 for it.
Tried using paint remover, but ended up just using a sponge with an abrasive side (almost like brillo). Took a about 20 minutes to do all 4 center caps. Let them dry, then gave all 4 a few coats of paint over the next 3 hours.
Popped them back on my 1997 Toyota 4Runner and presto back in action! Those ugly yellowing plastic caps are looking brand new. Don't even want to bother putting the black in for the toyota logo. Looks just as good and i don't feel the need to advertise for them.
Thanks all for the tips!
Look's GREAT Kregg. If ANYONE does this. I think it would be a great service to give out tips. Besides, Remember, we ALL have one thing in common....Mod addiction..So one sicko needs to help another sicko get his or her "FIX".:D
