DIY: Roof Rack Delete (w/ pics)
W8kbrder
I know this has been discussed in a few threads but I figured I would do a more detailed write-up for those that have never ventured down that path. So rather than some vague descriptions, here are the detailed steps on removing the 5th Generation Roof Rack. I had more detailed pictures to include throughout this thread, but it said I was limited to only 11 pictures. I originally had 18. Either way, hope it helps those with the questions.
1.) Order your parts: The following parts will be needed to accomplish the roof rack delete. You will need the following:
8pcs - Part# 90119-08C47 (roof bolts w/ rubber washers)
4pcs - Part# 63185-42020 (roof brackets w/ foam pads - TE already have this under the installed roof rack)
4pcs - Part# 75596-35030 (roof plastic covers)
RoofRack2.jpg~original
2.) Plastic Cover Removal: You will notice by the picture that there are two tabs holding the cover in place. These tabs face outward away from the car. On the front covers, the tabs are 3" and 7" measuring from front corner of the cover to the back of the cover. First tab at 3" ....2nd tab at 7". (see picture - You can start with either side first. I started with the driver side).
RoofRack13.jpg~original
3.) Cover Removal: All you need is a flathead screwdriver and a soft rag to pop these off. Carefully wedge the tip of the flathead between the cover and the rubber gasket that it sits on.
Put a rag over the car and slowly pry up the plastic cover.....you will hear it pop when the first tab is free. Move to the 7" mark and pry up/out the 2nd tab until you hear the pop sound. Once both tabs have been released, rotate the plastic cover back towards the roof of the car. This will expose the two bolts holding the roof rack in place.
RoofRack5.jpg~original
RoofRack6.jpg~original
4.) Use a Metric size 12 socket and unbolt the two bolts found under the cover. These are very tight at first and tough to turn as the factory put a type of red threadlocker on the bolt threads. Slowly loosen these and remove the two bolts under the front cover, and under the rear cover.
RoofRack7.jpg~original
This is the difference between the stock bolt (long/silver) and the roof rack delete bolts (black).
RoofRack8.jpg~original
5.) Remove entire driver's side roof rack. Once removed you will see this:
RoofRack9.jpg~original
There will be some bits and pieces of sticky black foam. I used a rag and wiped around the area...just to make sure it was free of any debris. This is important as once you replace this empty hole with the new brackets, a new seal will be made. The black metal brakets have a foam pad at the bottom of each end to prevent any water from entering into the screw holes.
*Note: You might want to put a bit of silicone around the base of these white tubes...just for good measure. The bracket foam pads paired with the rubber washers should do a good job of keeping any water out, but a little extra wouldn't hurt.
6.) Metal Brackets: Now its time to place the new metal brackets in their place. You will notice a little "arrow" imprinted in the bracket. I kept the arrow pointing outward toward the outside of the car. Now anyone can correct me on this as I do not have the repair/service manual, but I believe the arrows should point outward away from the car as this was the position that seemed to fit best.
RoofRack18.jpg~original
RoofRack16.jpg~original
7.) Install new Bolts: Once you have the new metal brackets in place, its now time to install the new bolts. I used a bit of blue medium strenght threadlocker on the end of each bolt to make sure it does not come loose. At the same time it should prevent any moisture from entering through the threads. Some people use build-a-gasket or teflon paste. Your choice. But the combination of the foam pads on the metal brackets and the rubber around the new bolt washer should prevent any water from entering. Use a metric size 11 socket to tighten these bolts in place (These bolt heads are a bit smaller than the stock silver ones. I can't remember the exact size...I'm pretty sure its metric size 11..... its one or two sizes smaller than the stock bolt). I'm not sure how tight they have to be, but usually my motto of "Tight is tight enough" should suffice.
RoofRack10.jpg~original
8.) Install Plastic Clip/Covers: Finally, install the plastic covers. These have arrows molded into them as well. Again, not sure exactly which direction they should go, but I installed them with the side arrow pointing outward away from the car. They seem to fit perfect that way.
THATS IT! Your done. Drink a beer and enjoy the clean look of the rackless 4Runner. :trophy:
...Some people use build-a-gasket or teflon paste. Your choice. But the combination of the foam pads on the metal brackets and the rubber around the new bolt washer should prevent any water from entering....
Nice Write up, IMO I would definitely add some form a gasket or silicon to the outside of those tubes, just cheap insurance as to keeping the interior dry. When I removed my stock TE rack a while back Toyota did have some type of sealant around the tubes and mine came with those metal brackets installed.
Nice write-up, that is the same parts I used on mine and did put a little silicone on the tubes and put silicone tape on the bolts.
I may do this just to be sure. The metal brackets have a thin foam padding around the foot of each bracket. The same went for the footings on the stock rack. I never found any type of sealant around the holes. It only appeared that the foam pads were functioning to prevent water from entering. The foam pad surrounds the hole so once tightened down, the pad squeezes and spreads out. I did a pretty thorough inspection and could not find any where that water could enter. But it may be wise to add something extra just to be safe!
I may do this just to be sure. The metal brackets have a thin foam padding around the foot of each bracket. The same went for the footings on the stock rack. I never found any type of sealant around the holes. It only appeared that the foam pads were functioning to prevent water from entering. The foam pad surrounds the whole so once tightened down, the pad squeezes and spreads out. I did a pretty thorough inspection and could not find any where that water could enter. But it may be wise to add something extra just to be safe!
Your parts department should have something called "dum dum", which is a licorice rope-like substance, that gets packed around those white tubes. The TE roof rails have it already, as do the 4Runners that came with no rails installed.
May I ask why do you remove the rack? What if you need to carry "stuff" on the roof for trips.
Well first of all, I did not have any crossbars....so unless I was carrying stuff sideways, then the rack served no purpose...especially since its chrome and we know how easy that stuff scratches up.
Second, I was originally going to paint the bars black so taking them off the vehicle was the only thing to do since my wife drives it daily....makes it easier on me.
Third, I just like the way it looks without the bars...much more clean to me. At some point down the road, I would be interested in that new baja flat rack.
Lastly, Harper7's vehicle inspired me to remove my roof rack as well b/c his rig looks awesome and I respect awesomeness. :)
Thanks Mike. I will definitly look into this. For now, I have used black silicone gasket maker. The stock rack definitely did not have any type of "dum dum" material or silicone for that matter. I carefully inspected each plastic footing on the rack. The only material keeping water out was the soft foam padding at the bottom of each foot and the rubber washer. Thats it. Maybe they left it out on mine?
Do you know if the substance is packed around the outside of the metal bracket.....or is is around the clear/white tubes and the bracket is placed over it?
thanks,
Nick
The stock stuff that was used in mine, I guess the "dum-dum" was around the outside of the tubes to cover the gap, then the metal brackets were placed over that. When I Installed my first Baja Rack, they recommended that you also place some form a gasket or Silicon on the bolts themselves before tightening everything down.
I do agree, without the OEM racks, the 4Runners do look pretty Sleek and Streamlined! Mine's been topless for about a month now.
thanks,
Nick
I don't think it comes on the SR5/LE racks because the bolt heads are covered. On my TE, it was around the white tubes so the gap was sealed and the metal brackets went over it.
When I replaced my TE rails with my Perkins rack, I used clear GE Silicone II to seal off those gaps and they've survived desert hear, mountain snow, torrential rain, and repeated overnight freezing. Not everyone is as paranoid as I am, though, which is why I mentioned the dum dum.
um, no, that's an FJ45 PICKUP!!! woot!
now back on topic, I'm thinking of trying to install a full rack, maybe a full length ARB? Anyone done this?
Excellent "How To"...but more important, is that a CHERRY (1994) CORRADO parked next to it?!?!?!?!?!?!? :naughty:
Hah...close. Its a cherry '93 Corrado SLC. Oh the tears of joy and tears of frustration I've had with that ride over the years. It got so expensive to fix that I took it upon myself to learn how to pull things apart and do it myself. Before I owned the Corrado, I only knew how to change an air filter. Now I can pull the entire engine/transmission and rebuild it from the bottom up....all thanks to my education at the University of Google. :bigok: Amazing what you can accomplish by reading through community forums.
c1.jpg~original
IMG_2574.jpg~original
I want to see what is in front of the Corrado! FJ-40?
In front of the Rado is a 1971 Series IIa Land Rover w/ Defender 90 axles/coils, transmission and transfer case, military spec engine w/ headwork, etc etc. I'm a huge Rover fan.
IMG_0926.jpg~original
RoverPro1.jpg~original
IMG_7994.jpg~original
IMG_0604.jpg~original
c1.jpg~original
You have some nice rides also, GREAT WRITE UP I myself will be doing the roof rack delete to ensure my RUNNER will fit in my garage after my lift goes on (old garages weren't made with much thought of these things). Thanks!
