Do 02 runners have ideal air control valve
ABOZEYAD
I am puzzled, my rig runs like a dream, lots of power and great picking up from stop and go. however from time to time at the traffic light i got this light drop of idel to about 550 RPM and feel the rattling in the steering wheel then back to normal again. last night i was stopping on the top of a hill and she started to roll back slowly on me. it freaked me out but the mechanic told me its because it was idling low. i went back again to the same hill , this time it didn't roll back it just stayed there instead of slowly move up.here is what i did so far
1- cleaned up the MAS
2- new air filter
3- new OEM spark plugs and wires (6month old)
4-new gas filter
5-sea foamed the hell outa of it
the reason i am asking for the IAC is because lots of threads here talked about cleaning up the IAC except that i cant fined mine around the TB.
please help.
1. It's idle air control not ideal
And
2. Yes you do have one but the '01 and '02 throttle bodies has it built in and you aren't able to access it to clean it.
And
thanks for the English correction. it was much needed ( disabled the auto correction on my iphone) because off this... however, did anybody ever access the IAC?
Just wanted to make sure if you are searching that you are searching for the right thing. And you can't access it, you can only test the resistance and see if it's in spec and if it's not then you have to replace the whole throttle body.
it looks like i might just take the TB of and do a thoroughly clean job on it , test it, and see my options from there on.
thanks for your help bro.:)
goddesszilla
