Dobinsons 5th Gen T4R Suspension options - from Exit Offroad
Mike,
Quick question on coils. I've got C302s on IMS shocks and I've had to add a good amount of preload + 1/4" top spacers to keep my ride height sitting around 22.75-23" hub to fender. I've got a RSG skid, C4 low pro, and winch. Plus I have a RTT on top part time.
I'm wondering if C354's would be overkill for a setup like this and ride a bit too rough? Maybe just stick with C314s if I swap coils?
Looking ahead for when I decide to rebuild stuff. Shocks are still doing great (about 55K on them now) but I'm sure I'll be rebuilding around 75-80K to keep the ride nice.
Mike,
Hey man,
You could go to the 354's and bring the coil seat back down and probably not need the spacers either. I have the same on my 4Runner with similar front weight and it rides well. The 314's would still be under a lot of compression, and I had those too. It rode better with the higher rate springs under less tension/preload.
Hey man,
Great to know - I was concerned if they would be too stiff!
C59-354
C59-701v
C59-300 in the front & C59-325 in the rear. Was going to sell my IMS at first to just use spacers from Westcott but I’m so glad I didn’t. Rides better than the Fox TRD Pro shocks 100%.
Looks great man!! That white truck with those black wheels really looks sweet!!
[MENTION=148378]Crikeymike[/MENTION]
Hitting you up here because I have no idea how to PM on the forum. Got some questions about what you may have in stock and what shipping to Alaska would look like on a Dobinson set up. I’m sort of torn between the twin tube set up and the mono. Budget says twin tube but internal want says mono. So would I be missing much if I don’t hardcore off road with the twin tube? I would honestly be only taking it truest off road on hunting/fishing trips. However, some of the roads up here aren’t paved for vast lengths and can be pretty rutty and basically trail like in the lower 48. I’ll send you an email through the site as well in case you don’t see this any time soon.
Replied to your email.
:hatsoff:
Hey guys, my name is Mike Tomczyk (aka Crikeymike), owner at ExitOffroad.com. I've been in the 4x4 industry since 1998 and have always preferred to focus on suspension for 4x4's, since it's something you'll feel every single time you move your vehicle, whether driving to work or home, or offroad for the weekend. Everyone has their own build plans for their vehicle, so no same combo of parts is necessarily right for everyone, which is why we offer such a variety - to get you exactly what you're looking for!!
I've been blasted with a lot of questions recently about our suspension offerings for the 5th Gen 4Runners, so I figured it's time to make a specific post about all that we offer. We can lift anywhere from 1.0" to 3.0" with coils and struts/shocks, and we can put together a specific package for whatever you want/need, including the added weight you've added to your vehicle.
Public Notice: Stock/New hub to fender measurements average out to 20" front and 22" rear, and all lift heights are based on that. Many people have 1/2" variance based on age and how the truck came off the assembly line. This video here shows you how to measure your baseline and lifted height:
<br>
<iframe width="560" height="315" src="https://www.youtube.com/embed/w7IgfWU1Awo" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<br>
Added Load Weight.
How much extra accessory weight have you added to your truck? Did you add a 150LB front bumper and an 80LB winch? That's constant weight, and will change which coil to buy.
Did you add our drawer system (hopefully) to the back end (150LBS) or a steel bumper with swing out tire carrier (200LBS)? That will also change which coil we would suggest.
You will want to consider that weight before ordering. If you order a heavy load coil without a heavy load, be warned that it won't ride as it's supposed to and the lift height will be incorrect.
Contact me directly if you have KDSS and I can walk you through our options for that. FYI, vehicles with KDSS should add our 15mm spacer (PS59-4025) onto the rear passenger side to correct the lean that usually happens on 1.5" or more of lift in the rear.
Full suspension builder page is here, with every part number and option offered for a 5th Gen 4runner:
Dobinsons 5th Gen Suspension Builder Page - Every Option
Dobinsons IMS 4Runner Lift Kit Builder Page
Dobinsons MRA 4Runner Lift Kit Builder Page
Click on each part number to be directed for further information
Front Coil Options, even height left to right. KDSS vehicles over 2" of lift should add PS59-4030 1/4" spacer to passenger side strut mount to correct the lean
C59-238 - Stock front end, low height lift, 1.0"-1.25" lift. 375/375mm, 17mm wire, 586LB (teal only)
C59-296 - Stock front end load, 1.4"-1.5" lift. 378/378mm, 17mm wire, 586LB (teal only)
C59-300 - Stock front end load, 1.75" lift. 385/385mm, 17mm wire, 586LB
C59-302 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
C59-302 - Stock front end load, 2.5" lift. 395/395mm, 17mm wire, 586LB
C59-314 - 80-150LBS medium load front weight, 2" lift. 405/405mm, 17mm wire, 586LB or these same coils will give 2.5" with light front accessory weight of 50-80LBS, or 3" of lift with no front accessory weight.
C59-350 - 220-300LBS heavy load front weight, 1.5" lift. 380/380mm, 18mm wire, 730LB
C59-352 - 220-300LBS heavy load front weight, 2.0" lift. 385/385mm, 18mm wire, 730LB
C59-354 - V6 - 220-300LBS heavy load front weight, 2.5" lift. 390/390mm, 18mm wire, 730LB
***2.5" or more of lift, new UCA's are recommended***
TRD PRO Front Coils
C59-748R - 1.0" Lift coils for TRD Pro 4Runners with Bilstein or Fox Pro Struts, designed to add 1" lift over stock Pro height, same spring rate as stock (518LBS) but taller coils to add lift, 14.09" free height (teal or red). WILL ONLY REPLACE COILS THAT ARE FLAT TOP AND BOTTOM, NOT THE 2021 UPDATED VERSION WITH THE STEP IN THE LOWER COIL SEAT
Rear Coil Options, even left to right height **for KDSS vehicles, use a 15mm (PS59-4025) rear spacer on the passenger side to correct the lean on lift heights of 1.5" or more
C59-323 - Stock height rear coils, same specs as rear TRD Pro OE coils, 375/375mm, 17mm wire, 220LB (teal only)
C59-599 - Stock rear end, 1.0"-1.25" lift (keeps rear end low, allowing to help level the vehicle rake with 2" front lift). 390/390mm, 17mm wire, 220LB
C59-505 - Stock rear end load, 1.5-1.75" lift. 405/405mm, 17mm wire, 220LB
C59-325 - Stock rear end load, 2.0-2.25" lift. 420/420mm, 17mm wire, 220LB
C59-327 - 200-400LB heavy rear load weight, 2" lift, 2.5" with stock weight. 410/410mm, 18mm wire, 271LB
C59-329 - 600-800LB super ridiculous heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 286LB (teal only)
C59-331 - 800LB+ insanely heavy rear end weight, 2" lift. 410/410mm, 19mm wire, 349LB (teal)
C59-675V - Variable rate comfort option, stock rear weight, 3" lift. 470/470mm, 16mm wire, 157-230LB variable
C59-677V - Variable rate, 200-400LB constant rear load weight, 3" lift, long travel. 500/500mm, 16mm wire, 157-230LB variable
C59-701V - Variable rate, 500-600 LB heavy rear load weight, 3" lift, long travel. 500/500mm, 17mm wire, 210-245LB variable. Designed for those with heavy full rear bumper, tire carrier, roof rack, RTT, drawers, and fridge. Rides very well with all that weight, as well as when loaded even further.
C59-749V - Variable Rate, 800-1000 LB super heavy constant rear load, 3" lift, long travel. 520/520mm free height, 18mm wire, 198-300LB variable rate, usually around 270LB at loaded height
Note: Vehicles with KDSS should be lifted no more than 2.5" in the rear or you will probably have a lean that you cannot correct unless you add additional parts like these: Treaty Oak KDSS Spacer Kit
Front Strut Options
GS59-700 - Twin Tube, fixed mount (not adjustable), suits 0-2.5" lift (555mm extended, 432mm compressed), can be used on stock height or lifted vehicle, use with OE or aftermarket coils, coil seat mount same as OE
GS59-574 - Twin Tube, fixed mount (not adjustable), extended travel (22.63" / 575mm extended, 430mm compressed), use with 2" coil to get 3" lift (coil seat height is 13mm higher than OE, resulting in ~1" of lift). Using this with a 3" length coil would give 4", so not recommended. Diff drop kit is required to run these, as CV's will bind at full down travel due to the extended length.
IMS59-50700 - IMS Front Struts - suits 0-3" lift - 560mm extended, 420mm compressed
IMS59-50574 - IMS Front Extended Travel Struts - suits 2-3.5" lift - 575mm extended, 430mm compressed
MRA59-A700 - MRA 3-way adjustable monotubes - suitable for 0-3" front lift. 560mm extended, 420mm compressed
MRA59-A574 MRA 3-way adjustable monotubes Front Extended Travel - suitable for 2-3.5" lift - 575mm extended, 420mm compressed
Rear Shock Options
GS59-701 - Twin Tube, suits 0-2.5" lift. 605mm extended, 362mm compressed
GS59-705 - Twin Tube, suits 0-2.5" lift, softer valving for empty rear ends. 590mm extended, 355mm compressed
GS59-575 - Twin Tube, Long Travel, suits 3-3.5" lift (3" bump stop spacers recommended so shocks don't bottom out). 730mm extended, 425mm compressed. - Cannot be used with KDSS
IMS59-50705 - IMS Rear Shocks comfort valved - suits 0-3" lift - 590mm ext, 385mm comp
IMS59-50701 - IMS Rear Shocks standard valving - suits 0-3" lift - 598mm ext, 389mm comp
IMS59-50575 - IMS Rear Long Travel Shocks - suits 3-3.5" lift (not for KDSS models) - 720mm ext, 438mm comp
MRA59-A701 - MRA 3-way adjustable monotubes - suitable for 0-3" rear lift. 609mm extended, 389mm compressed
MRA59-A575 - MRA 3-way adjustable monotubes - Long Travel - suits 3-3.5" lift - 730mm extended, 443mm compressed
Dobinsons 3-way adjustable MRA struts and shocks have their own thread, here: Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen VIDEO LINK
Diff Drop Kit
DD59-527K - required with 3" lift, could also be used for 2" to 2.5" lifts if desired to correct CV angle
Adjustable Panhard Rod
PR59-1423 - Rear adjustable panhard rod, realigns rear axle back to center when lifted 3"+ VIDEO LINK
Adjustable Rear Control Arms
WA59-520K - Rear Lower Adjustable Control Arms
WA59-522K - Rear Upper Adjustable Control Arms
Front sway bar relocation kit (only for non-KDSS vehicles)
Gains clearance around bigger/thicker front struts and coils, if needed, as well as helps correct sway bar operating angle with lifts over 2". (currently in re-design)
Rear sway bar extended length end links
SE59-529 - Suits lift up to 4". Uses factory style ball joint ends, gold zinc plated. Repositions rear sway bar to original position to remove stress from the rear end and correct the amount of wheel travel. VIDEO LINK
Front UCA's
UCA59-002K - Front UCA Set with Senkei 555 Ball joints - Pair of replacement upper control arms to fix alignment issues with 2.5"+ lift heights. Use OE type rubber bushes on the frame end, and replaceable high angle ball joint on the wheel side. 38mm OD tube, 5mm wall thickness (0.2") HSLA steel. Fixed caster of 3 degrees built in. VIDEO LINK
Front Strut Top Caps/Hats
SC59-001 - New upper caps - don't waste time pulling apart your old strut assembly just to get the cap off, buy new. Or better yet, we can assemble the units before shipping so you can install at home faster.
Front Top Mount Strut Spacer - new February 2019
PS59-4030 - Single 1/4" machine alloy strut spacer, anodized black, suits almost all Toyota's from the 90's to current. Drilled with 2 bolt patterns to fit multiple vehicles. 4Runner 3rd, 4th, and 5th Gen. All Tacoma's 1998 to 2019. All GX470/460. All FJ Cruisers. Can be used to correct a vehicle lean if one exists, or to add one to both sides to add 1/2" lift.
Rear Coil Spacers
PS59-4025 - Single 15mm Poly Coil Spacer to correct vehicle lean - recommended for vehicles with KDSS, install on the passenger side
CV Boot Kits
High clearance stretch style CV boots for the outer or inner position of the front shafts. High quality silicone, includes all new grease and clamps - great for lifted vehicles with higher angle CV's which are prone to boot failure. Boots have better designed bellows, less likely to rub and make contact with each other for longevity.
CV59-554K - Outer CV Boot Kit
CV59-557K - Inner CV Boot Kit (new September 2020)
We stock these parts in Miami, but if we were to run out, or have to make a special order, or custom make some coils, they would ship from Queensland, Australia.
What we get the most demand/requests from customers is our 3" front and 2" rear (leveling the vehicle), or 3" front and 3" rear progressive/variable rate coils with long travel struts and shocks. This will give the most travel and flex with just a few extra components needed. We also have options for 3/3", 2/2", 2/1", 2.5/1.5", or whatever lift height options you want to run. Lately, 2" front and 1" rear is very common (300 and 599 coils).
Added 8/29/17: Here is an album I just created trying to collectively gather all the photos I can of installed Dobinsons products. I'm showing the part numbers used and lift height gained, where possible.
Check out gallery here
Update 12/15/17.
Bring on the kicking and screaming from those who have already bought..... :wacko: :yield:
Due to popular demand and an amazing amount of requests, we have brought our most common 4Runner (and Toyota) coils to the US in 2 additional colors. Red and black. Now these part numbers are available (depending on stock) in classic Dobinsons Teal, TRD Red, and/or Black, depending on part number.
C59-300 (Teal, red or black)
C59-302 (Teal, red or black)
C59-314 (Teal, red or black)
C59-350 (Teal, red or black)
C59-352 (Teal, red or black)
C59-354 (Teal, red or black)
C59-599 (Teal, red or black)
C59-505 (Teal, red or black)
C59-325 (Teal, red or black)
C59-327 (Teal, red or black)
C59-675V (Teal, red or black)
C59-677V (Teal, red or black)
C59-701V (Teal, red or black)
C59-749V (Teal, red or black)
Of course, we would prefer to sell the teal for branding reasons, but so many of you this year have asked us for a color choice, so here you go!!
NOTE: the optional colors are not listed in the catalog, and are not sold on Amazon or Ebay. You have to contact me directly and let me know what you want. They're all the same price as usual. As usual, send me an email to [email protected]
<iframe width="560" height="315" src="https://www.youtube.com/embed/CmjVHhuT1vU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/Npfx40VD3kM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZjF37uC4n-M" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/na5NvdfxOrM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/RgyemIrnzsQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/lZACSaE2PHI" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/qtkesMe4ddE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I have a question. C59-331 how high will this spring sit without weight in the rear and how does it ride? I do tow on occasion(car trailer)
You would NOT buy that spring unless you have all of that constant weight on the truck, constant meaning always on the vehicle.
I sell about 4-5 sets of those per year because hardly anyone runs that heavy.
To answer your question - I can't. Don't buy those springs unless you want a 2" lift with at least 800lbs of constant rear weight bolted to the vehicle.
Hey Mike,
So would this work for ~2" lift (and is there any reason not to do the extended travel front shocks if only looking for 2" lift)?
Front:
C59-238 coils
GS59-574 shocks
Rear:
C59-505 coils
GS59-701 shocks
or would I be better off going with C59-300 coils and GS59-700 shocks?
Any need for anything else (extended brake lines, etc)? Stock weight, probably going to add rock sliders and possibly a front bumper (just the center portion and without a winch) down the road...
I'm still kinda feeling things out since I'm still waiting for my 4Runner. First thing I'm doing is having them swap the tires though...
Hey Mike,
Front:
C59-238 coils
GS59-574 shocks
Rear:
C59-505 coils
GS59-701 shocks
You only get the benefit of the extended travel front struts when you add UCA's, so no, running C59-300's with GS59-700's is the better way to go.
The rest looks good. No, you don't need any other parts with that lift height front and rear.
Any shock and coil upgrade will improve body roll considerably. These vehicles come with very soft coils and shocks from the factory.
People say the IMS rides better with more weight added, and that's common with any suspension. So it won't get worse when loaded or anything like that.
Hey Mike, I ordered IMS kit 700/701. I just received a note that Im getting a 705 revalved to match 701 valving. I looked up the difference between the two, the 705 has shorter extended and compressed length by 10mm. Does this mean I’m getting shorter shocks?
Dobinsons said they took the 705's and changed them into the 701's. They probably changed the top out spacer inside the shock body as well.
Hey Mike,
I'm looking to upgrade from my basic twintube OME set up to the IMS set up from Dobinson. The parts I'm looking at are below:
Front Springs: C59-352
Front Shocks: IMS59-50574 Monotube IFP Shocks 2.5"-3.5" (1" added Height)
Rear Springs: C59-331
Rear Shocks: IMS59-50701 Monotube IFP 0-3" Lift
DD59-527K Diff Drop
My question is about the springs if they're over kill or not. I have a full drawer system, fridge, full rear bumper w/spare carrier, full skids, GOBI rack, RTT, front bumper & winch (I'm sure I'm forgetting something) .
I was leaning towards the heavier load stuff because I went too light before and now I barely have a lift at all. I'd rather have a stiffer ride and not have issues with settlement or rubbing in the future. (my other ride is a lifted ram 2500 so this thing will ride better no matter what, lol)
Am I on the right track or do you recommend lighter springs?
