Doing a front wheel bearing myself... do they need to be pressed or not?
babyeater304
Everyone, including the service guy at my local dealership, says they need to be pressed and I either need to have a shop do the whole thing or have a machinist press them. However, over on yotatech I read about people that have done bearing replacements themselves with no press. And then, there is this 5-part youtube tutorial where the guy does it with no press.
DIY: 1994 4runner Front Brake Job incl. new Rotors & Wheel Bearings (Part 3 of 5) - YouTube
However that's a '94. I have a 2002 SR5. However, I asked the service guy at my dealership and he said there is no difference between the two.
I don't want to pay the quoted $500 to have the dealer do it. Is it possible to do by myself if I just order them online? And if I do order them online, will it come with everything I need (except the grease, of course) to replace them?
Also, i'm considering for the price to just replace the whole hub. Good idea, bad idea?
Every 3rd gen wheel bearing is pressed in since they are sealed. Buy a 20 ton press or have the dealer/machine shop do it.
That said, if you can get the knuckle off for the front and the axle out of the back, that will save ya some $$$ in labor costs.
Pretty sure they are in fact a sealed bearing ( much different setup than the video you posted.
A lot of shops will have a tool set called a"hub tamer", that they can push the old bearing out and a new one in while the steering knuckle remains on the vehicle.
Never did this to the Runner but recently did a 1996 Camry bearing, this way.
I pulled the spindle and beat the old bearing out and took the spindle and new bearing to a local shop and they used their hub tamer to press the new bearing in, for $35.00
I used a gear puller and was able to change out my wheel bearings. It is easy. It is easier if you have a press.
The vdo posted is not how our wheel bearings are. Ours are less complicated.
a "special" gear puller is actually what the Toyota service manual shows as well. I tried a gear puller on mine first, but it wouldn't budge the hub. I ended up using a 12ton press and some pieces of I beam to do it.
and yes first and second gen are serviceable bearings (like the vid), 3rd gen are pain in the ____ pressed in, and 4th and i believe 5th are bolt in.
