19963.4lsr5
Do you have the dome circuit wiring for your 99? If so can you post a copy of it so I can review it?
The lights are dome light themselves are good. I tested them straight off the battery and they are plenty bright.
I have the radio totally disconnected as well as the combination meter, that's the only time the lights come on but they are very dim. As soon as I connect the radio or the blue connector on the back of the dash they shut off completely.
I will try pulling other fuses to see if that changes anything but I'm convinced it has something to do with the combination meter. I filled up my gas tank yesterday, went to reset my trip odometer and it was at like 35 miles. Reset it anyway and drove home (5miles). Started it up to head to work this morning and it had reset itself. Every time I turn the truck off and it sits the odometer resets itself.
SO would I be correct in thinking the dash itself is the problem?
As the 3rd Gen became more modern more and more things that use to he hard wired became distributed modules. You’re instrument cluster is no exception. It’s digital? Yes?
It looks like it is in control of your dome light controls and if your odo is crewing up.......I’d look for a cluster with similar milage and buy it and see how it behaves.
My old 04 Grand Cherokee had modules everywhere. Seats, doors, instrument cluster.....it was there way of saving money on copper wire and having a 2 wire communication bus sending info locally to control things.
In 99 Toyota completely changed their engine and body controls. Your milage may vary....
can't speak for exactly what's in [MENTION=274758]906-Runner[/MENTION] 's dash but mine is the same year and SR5 spec, and it's not digital. i've had the cluster off too many times to admit to, and it's the old-style boxy thing with spring-load twist lights and exposed traces all around the board, and three molexes to connect the silly thing to their extra-short cables.
The combination meter is the instrument cluster? If your 99 is still analog gauges without digital ODO is it the correct diagram. My 97 drawing shows something else in place of the combo meter.
Got my volt meter tester yesterday and tried it out today. I have continuity everywhere, I tested resistance as well and got around 1 Ohm between all connections except one. I had 12 Ohms between my dash and my radio; I’m guessing it must be pinched or something, but still barely connected? Any ideas how I could figure out what it is?
Using a test light and using the bright bulb- dim bulb-no bulb
If the OP isn’t mindful putting that meter of his to Amps he will blow the internal fuse. It can’t be used in the same way switched to amps as one does measuring voltage and resistance.
I got a bit lost reading your posts, and have a total noob question. How am I supposed to test the dome plug for voltage without risking blowing the internal fuse on my meter?
I tested between the prongs on the dome light and I'm only getting about 2 volts; clearly I have too much resistance somewhere but now I've got to track it down.
Did you pull the led out of the socket when you had 2v at the prongs?
What were you putting your black lead on for ground.
